HPE ProLiant ML350 Gen10 310 4110 Xeon-S/8 Core 85W 2100 Skylake
Quicklinx: DV1WWS00 Mfr#: 877621-421
Case Style: Tower
Processor Type: Xeon Silver
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 16GB
Hurry, only 3 left in stock!
£1,445.40 ex VAT
£1,734.48 inc VAT
Do you need a robust server for your SMB and remote offices? HPE ProLiant ML350 Gen10 Server delivers a secure dual-socket tower server with performance, expandability, and proven reliability making it the choice for expanding SMBs, remote offices of larger businesses, and enterprise data centers. HPE ML350 Gen10 Server leverages the Intel Xeon Scalable processors with up to 71% performance gain and 27% increase in cores , along with the 2666 MT/s HPE DDR4 SmartMemory supports up to 3.0 TB and 11% faster than 2400 MT/s. The shorter re-designed rackable chassis with multiple upgrade options provides flexibility that can expand as your business needs grow. It supports 12 Gb/s SAS, NVMe SSD, embedded 4x1GbE NIC with a broad range of graphics and compute options. Supported by the HPE Pointnext industry-leading service organization and ease of deployment, HPE ML350 Gen10 Server helps you transform to a digital business with more agility and all within your limited IT budget.
  • Perform with Unmatched Versatility
    HPE ProLiant ML350 Gen10 supports up to two Intel Xeon Scalable processors, starting from Bronze through Platinum, 4 cores expanding up to 28 core processors offering unparalleled performance.Up to 24 DIMM slots to support the 2600 MT/s HPE DDR4 SmartMemory, reducing data loss and downtime with the HPE Gen10 technology licensed Fast Fault Tolerance feature while increasing workload performance and power efficiency.It supports a wide range of solutions from Azure to Docker to ClearOS along with the traditional operating systems.GPU expansion supports up to four units to accelerate performance in VDI applications and machine learning for financial services, surveillance and security, educational and scientific research, as well as retail and medical imaging.
  • Expand When Your Business Needs Grow
    HPE ProLiant ML350 Gen10 delivers expandability with a wide range of drive upgrade options. Supporting 8 to 24 SFF or 16 SFF when mixed with optional 8 NVMe PCIe solid state drives, 4 to 12 LFF hot plug or non-hot plug drive options protecting your IT investment in hybrid environment.Large expansion capacity with (8) PCIe slots, (6) USB ports, 5U rack conversion, and power supply options.Embedded 4x1GbE and the choice of PCIe standup 1GbE, 10GbE or 25GbE adapters provide you the flexibility of networking bandwidth and fabric so you can scale and adapt to different needs as your business grows.
  • Security Innovations
    HPE ProLiant ML350 Gen10 is one of the HPE industry standard servers with major firmware anchored directly into the silicon security protection built in across the server lifecycle starting with Silicon Root of Trust.Millions of lines of firmware code run before server operating system boots. With Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last, known-good state or factory settings after detection of compromised code.Additional security options are available with Trusted Platform Module (TPM) to prevent unauthorized access to the server and reliably store artifacts used to authenticate the server.
  • Industry Leading Services and Ease of Deployment
    The HPE ProLiant ML350 Gen10 comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk, and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an effective solution. Professional Services enable rapid deployment of solutions and Operational Services provide ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant ML350 Gen10 Base - tower - Xeon Silver 4110 2.1 GHz - 16 GB
Server - tower
Height (Rack Units)
4U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 768 GB (max) DDR4 SDRAM - Advanced ECC
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
GigE
Power Redundancy
Optional
17.4 cm x 64.8 cm x 46.25 cm
21 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Tower - 4U
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 768 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, Online Spare Memory, HPE SmartMemory, 6-channel memory architecture
Configuration Features
1 x 16 GB
RAM Supported
3 TB Load-Reduced - Advanced ECC , 768 GB registered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 369i
Remote Management Protocol
SNMP 3, IPMI 2.0
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 2 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x VGA , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HP iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 1 x USB 2.0 (1 internal) , 1 x HP iLO - Type A (1 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
Software
HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
ENERGY STAR Certified
ENERGY STAR Version
2.1
17.4 cm
64.8 cm
46.25 cm
21 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
27 dBA
Case Style: Tower
Brand: HPE
Price Range Ex VAT: 1000 - 1500
