Does your remote or branch office need a server that delivers the essential availability and expansion to accommodate your changing business needs? The HPE ProLiant ML30 Gen9 Server is an affordable single-socket tower server that features value performance, expansion, and growth that is ideal for small businesses and remote branch offices.
- HPE ProLiant ML30 Gen9 - micro tower - Xeon E3-1220V6 3 GHz - 8 GB - HDD 1 TB
- Server - micro tower
- Localisation
- Region: United Kingdom
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1220V6 / 3 GHz (, up to 3.5 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s) - PCIe x4 (HP Dynamic Smart Array B140i)
- Server Storage Bays
- 3.5"
- Hard Drive
- HDD 1 TB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 18.8 cm x 49.15 cm x 37.85 cm
- 13.56 kg
- Manufacturer Selling Program
- HP Top Value
- Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site
- Server
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Hot-Swap Bays Qty
- 4
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1220V6
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel C236
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total)
- Unbuffered, dual channel memory architecture
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID - PCIe x4
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B140i
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" , 4 (total) / 3 (free) x 3.5" LFF
- Slots
- 4 DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 6 x USB 3.0 (4 front, 2 rear) , 4 x USB 2.0 (2 rear, 2 internal)
- ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, GB 9254, CNS 13438
- HP Top Value
- Power supply
- Voltage Required
- Power Provided
- 350 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 18.8 cm
- 49.15 cm
- 37.85 cm
- 13.56 kg
- 0 °C
- 40 °C
- 10 - 90%
