HPE ProLiant ML30 Gen9 E3-1220v6 Quad Core 72W 3500 Kabylake
Quicklinx: DV1GWS00 Mfr#: P03705-425
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Does your remote or branch office need a server that delivers the essential availability and expansion to accommodate your changing business needs? The HPE ProLiant ML30 Gen9 Server is an affordable single-socket tower server that features value performance, expansion, and growth that is ideal for small businesses and remote branch offices.
  • Unlock Your Infrastructure's Potential with Easy-to-Use Integrated Management and Support
    The HPE ProLiant ML30 Gen9 Server offers HPE iLO Management, a complete set of embedded features, standard on all ProLiant Gen9 Server products. Includes HPE iLO with Agentless Management, Active Health System, Intelligent Provisioning, and Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while decreasing time-to-resolution.HPE Insight Online with Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE Smart Update Solution reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes Smart Update Manager (SUM), and Service Pack for ProLiant (SPP), and other products.
  • Near Continuous Data Protection
    The HPE ProLiant ML30 Gen9 Server Smart Array options provide businesses RAID mirroring and striping capability to protect critical data while the Flash-Backed Write Cache (FBWC) captures and holds data indefinitely in the event of a power loss, equipment failure, human error or virus attacks.HPE Smart Drives improve serviceability and prevents data loss with features such as icon-based status display and Do Not Remove LED.ECC memory protects businesses from data loss and unplanned system downtime.
  • Flexible Options To Meet Changing Business Needs
    The HPE ProLiant ML30 Gen9 Server provides HPE SmartDrives which offers more drive options including eight Small Form Factor (SFF) and four Large Form Factor (LFF) drive cages giving you flexibility for increased capacity for your local storage. Support up to 8 TB per slot.It supports 2400 MHz DDR4 memory, with up to four DIMMs (64 GB maximum) for increased performance.Four PCI Express (PCIe) slots, including four PCIe 3.0 slots, provide additional I/O performance.
  • Seamless Network Connectivity Extends Benefits of Converged Infrastructure
    The HPE ProLiant ML30 Gen9 Server offers compatibility with 24-port HPE 1810 Series Switches to enhance both connectivity and data availability.Common pool of resources and applications results in a higher level of simplicity and flexibility in operations.User-friendly interface on HPE PS1810 Series Switches allow for a consolidated view of servers and switches in the network so workloads can be prioritized.
HPE ProLiant ML30 Gen9 Performance - tower Xeon E3-1220V6 3 GHz - 8 GB - no HDD
Server - tower
Height (Rack Units)
4U
Region: Europe
Server Scalability
1-way
1 x Intel Xeon E3-1220V6 / 3 GHz (up to 3.5 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB L3 Cache
Cache Per Processor
8 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-19200
Storage Controller
RAID (SATA 6Gb/s) - PCIe x4 (HP Dynamic Smart Array B140i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200
1GbE
17.5 cm x 47.52 cm x 36.82 cm
13.56 kg
Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
4
Region: Europe
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C236
Cache Memory
Installed Size
L3 Cache - 8 MB
Cache Per Processor
8 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
RAM Supported
64 GB unbuffered
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe x4
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200
Video Interfaces
VGA
Interface (Bus) Type
PCI Express x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" , 4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x4 - full-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 microSD Card (internal)
1 x VGA (1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 6 x USB 3.0 (4 front, 2 rear) , 4 x USB 2.0 (2 rear, 2 internal)
ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, GB 9254, CNS 13438, K22, K24
Power supply
Installed Qty
1
Power Provided
350 watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
17.5 cm
47.52 cm
36.82 cm
13.56 kg
10 - 90%
Sound Emission
23 dBA
Internal Hard Drives (1)
DV1G HPE 300GB SAS 15K SFF SC DS-Stock In Stock £456.47
Other bundles (2)
DV1G HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack In Stock £196.94
DV1G HP iLO Adv incl 3yr TS U E-LTU In Stock £310.83
