HPE ProLiant ML110 Gen10 310 4110 Xeon-S/8 Core 85W 2100 Skylake
Quicklinx: DV1SWS00 Mfr#: P03687-425
  • Red Hat Enterprise Linux
Are you searching for a tower server with exceptional value to meet the requirements of your small-to-midsized business? The HPE ProLiant ML110 Gen10 server is an enhanced tower with performance, expansion, and growth at an affordable price. It meets most small- and mid-sized businesses' needs as well as accelerates your business compute. The ProLiant ML110 Gen10 is a single processor tower form factor that can also be placed in a rack server cabinet using 4.5U of rack space. It includes up to five PCIe slots with room to grow with eight large form factor (LFF) or 16 small form factor (SFF) disk drives. It provides six DDR4 DIMM slots supporting HPE DDR4 SmartMemory with a maximum capacity of 192 GB. The HPE ProLiant ML110 Gen10 server also offers optional redundant fan and redundant power supply to satisfy automatic fail-over needs, making this the ideal server for small- to mid-sized businesses and remote offices and branch offices.
  • Right-sized, With the Balance of Performance To Meet Growing SMB Requirements
    The HPE ProLiant ML110 Gen10 Server is compact with less than a 19-inch depth, quiet, and affordable that can deliver the performance needed for the compute demands of a growing office small- to mid-sized business.Supports industry standard technology leveraging the Intel Xeon Scalable Processors operating with speeds of up to 3.6 GHz and up to 14 cores offering improved performance.Supports up to two optional graphic processing units (GPUs) allowing one double wide and one single wide card to boost performance in graphic and Virtual Desktop Infrastructure (VDI) applications such as financial services, education, scientific research and medical imaging.The embedded HPE Dynamic Smart Array S100i Controller for SATA disk drives supports boot, data and media needs. These enhanced HPE Smart Array Controllers provide the flexibility to choose the optimal 12 Gbps controller most suited to your environment, as well as operate in both SAS and HBA modes.Build a fully functional server with ClearOS Software from Hewlett Packard Enterprise that is just right for you at no upfront cost.
  • Expandability To Fit the Needs of Growing, Budget-conscious Businesses
    The HPE ProLiant ML110 Gen10 Server offers up to six DIMM slots with support for up to 192 GB of HPE DDR4 SmartMemory, helping to prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency.Support optional redundant fan and redundant power supplies reducing data loss and downtime, making your server more reliable. Flexible expansion capacity with five PCIe expansion slots, eight USB ports and one optional serial port.HPE SmartDrives delivers enhanced performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics. Support up to eight large form factor (LFF) disk drives or 16 small form factor (SFF) disk drive options.
  • Security Innovations
    The HPE ProLiant ML110 Gen10 Server is part of the Hewlett Packard Enterprise offering of industry-standard servers with major firmware anchored directly into the silicon. With security protection built-in across the server lifecycle starting with Silicon Root of Trust.Secure Recovery allows server firmware to roll back to the last known reliable state or factory settings after detection of compromised code.Millions of lines of firmware code run before server operating system boots and with Run-time Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.
  • Industry-Leading Services and Ease of Deployment
    The HPE ProLiant ML110 Gen10 Server comes with a complete set of services from HPE Pointnext, delivering confidence, reducing risk, and helping you realize agility and stability.HPE Pointnext Services simplifies all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an enchanced solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
HPE ProLiant ML110 Gen10 Solution - tower - Xeon Silver 4110 2.1 GHz - 16 GB - no HDD
Server - tower
Height (Rack Units)
4.5U
Server Scalability
1-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (8-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 192 GB (max) - DDR4 SDRAM
Storage Controller
RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
1GbE
19.5 cm x 48.05 cm x 44 cm
13.5 kg
Manufacturer Selling Program
HPE Top Value
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Tower - 4.5U
Server Scalability
1-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 192 GB (max)
DDR4 SDRAM
DIMM 288-pin
Slots
6 (Total) / 5 (empty)
Registered
Configuration Features
1 x 16 GB
RAM Supported
PC4-21300 - 192 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HPE 332i
Remote Management Controller
Integrated Lights-Out Advanced Management (ASIC)
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height
1 x VGA (1 rear) , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 (1 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 3 x USB 2.0 (2 rear, 1 internal) , 1 x HPE iLO - Type A (1 in front)
PCI DSS, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
HPE Top Value
Power supply - hot-plug
Installed Qty
1
Power Provided
800 Watt
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, CentOS, ClearOS
19.5 cm
48.05 cm
44 cm
13.5 kg
10 °C
35 °C
8 - 90% (non-condensing)
Internal Hard Drives (1)
DV1S HPE 1TB 6G SATA 7.2K 2.5IN SFF In Stock £406.28
Other bundles (2)
DV1S HPE HP Ethernet 1Gb 4-port 331T Adapter In Stock £81.28
DV1S HPE Ethernet 1GB 4-Port 366T Adapter In Stock £164.89
