Are you searching for a tower server with exceptional value to meet the requirements of your small-to-midsized business? The HPE ProLiant ML110 Gen10 server is an enhanced tower with performance, expansion, and growth at an affordable price. It meets most small- and mid-sized businesses' needs as well as accelerates your business compute. The ProLiant ML110 Gen10 is a single processor tower form factor that can also be placed in a rack server cabinet using 4.5U of rack space. It includes up to five PCIe slots with room to grow with eight large form factor (LFF) or 16 small form factor (SFF) disk drives. It provides six DDR4 DIMM slots supporting HPE DDR4 SmartMemory with a maximum capacity of 192 GB. The HPE ProLiant ML110 Gen10 server also offers optional redundant fan and redundant power supply to satisfy automatic fail-over needs, making this the ideal server for small- to mid-sized businesses and remote offices and branch offices.
Right-sized, With the Balance of Performance To Meet Growing SMB Requirements
The HPE ProLiant ML110 Gen10 Server is compact with less than a 19-inch depth, quiet, and affordable that can deliver the performance needed for the compute demands of a growing office small- to mid-sized business.Supports industry standard technology leveraging the Intel Xeon Scalable Processors operating with speeds of up to 3.6 GHz and up to 14 cores offering improved performance.Supports up to two optional graphic processing units (GPUs) allowing one double wide and one single wide card to boost performance in graphic and Virtual Desktop Infrastructure (VDI) applications such as financial services, education, scientific research and medical imaging.The embedded HPE Dynamic Smart Array S100i Controller for SATA disk drives supports boot, data and media needs. These enhanced HPE Smart Array Controllers provide the flexibility to choose the optimal 12 Gbps controller most suited to your environment, as well as operate in both SAS and HBA modes.Build a fully functional server with ClearOS Software from Hewlett Packard Enterprise that is just right for you at no upfront cost. -
Expandability To Fit the Needs of Growing, Budget-conscious Businesses
The HPE ProLiant ML110 Gen10 Server offers up to six DIMM slots with support for up to 192 GB of HPE DDR4 SmartMemory, helping to prevent data loss and downtime with enhanced error handling while improving workload performance and power efficiency.Support optional redundant fan and redundant power supplies reducing data loss and downtime, making your server more reliable. Flexible expansion capacity with five PCIe expansion slots, eight USB ports and one optional serial port.HPE SmartDrives delivers enhanced performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics. Support up to eight large form factor (LFF) disk drives or 16 small form factor (SFF) disk drive options. -
Security Innovations
The HPE ProLiant ML110 Gen10 Server is part of the Hewlett Packard Enterprise offering of industry-standard servers with major firmware anchored directly into the silicon. With security protection built-in across the server lifecycle starting with Silicon Root of Trust.Secure Recovery allows server firmware to roll back to the last known reliable state or factory settings after detection of compromised code.Millions of lines of firmware code run before server operating system boots and with Run-time Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware. -
Industry-Leading Services and Ease of Deployment
The HPE ProLiant ML110 Gen10 Server comes with a complete set of services from HPE Pointnext, delivering confidence, reducing risk, and helping you realize agility and stability.HPE Pointnext Services simplifies all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an enchanced solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE IT investment solutions help you transform to a digital business with IT economics that align to your business goals.
- HPE ProLiant ML110 Gen10 Solution - tower - Xeon Silver 4110 2.1 GHz - 16 GB - no HDD
- Server - tower
- Height (Rack Units)
- 4.5U
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon Silver 4110 / 2.1 GHz (8-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 192 GB (max) - DDR4 SDRAM
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- 19.5 cm x 48.05 cm x 44 cm
- 13.5 kg
- Manufacturer Selling Program
- HPE Top Value
- Limited warranty - parts and labour - 3 years - on-site
- Server
- Product Form Factor
- Tower - 4.5U
- 1-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
Processor / Chipset
- CPU
- Intel Xeon Silver 4110
- Clock Speed
- 2.1 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- 16 GB / 192 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Slots
- 6 (Total) / 5 (empty)
- Registered
- Configuration Features
- 1 x 16 GB
- RAM Supported
- PC4-21300 - 192 GB registered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software
- Channel Qty
- 10
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HPE 332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out Advanced Management (ASIC)
- Wake on LAN (WoL), PXE support
- Bays
- 1 (total) / 1 (free) x external 5.25" , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height
- 1 x VGA (1 rear) , 2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 (1 rear) , 5 x USB 3.0 (2 front, 2 rear, 1 internal) , 3 x USB 2.0 (2 rear, 1 internal) , 1 x HPE iLO - Type A (1 in front)
- PCI DSS, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- HPE Top Value
- Power supply - hot-plug
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 800 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, CentOS, ClearOS
- 19.5 cm
- 48.05 cm
- 44 cm
- 13.5 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
Internal Hard Drives (1)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £406.28 |
Other bundles (2)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
