HPE ProLiant MicroServer Gen10 X3421 16GB
Quicklinx: CZX0WS00 Mfr#: 870210-421
  • Opteron
The HPE ProLiant MicroServer Gen10 delivers an affordable, compact server specifically designed for small offices, home offices, or small business environments. This compact and easy to use server can be placed almost anywhere. Simple access to the hard drives, memory and PCIe slots allows easy management, installation and upgrades.
  • Be Productive and Customize With ClearOS Software from HPE
    The HPE ProLiant MicroServer Gen10 can be configured with ClearOS Software from HPE, an operating system with an intuitive Web based GUI and application marketplace that can be factory pre-loaded for your convenience.The ClearOS Software from HPE is a no cost operating system and you decide what applications you want to configure while only paying for the applications and support you require.
  • Unique Server Design with Worry-free Serviceability
    The HPE ProLiant MicroServer Gen10 is available with easy access to hard drives, memory, and PCIe slots for simple installation or upgrade.Compact, easy to use and can be placed in almost any location with its compact design.
  • Graphic Performance
    HPE ProLiant MicroServer Gen10 supports the AMD accelerated processing unit (APU) with the graphics core embedded to aid customers with graphics related workloads without installing an additional graphic card.Dual display ports capable of 4K resolution video display for increased flexibility.AMD Radeon Pro WX 2100 boosts up your graphics experience by offering the new generation Graphics Core Next (GCN) GPU architecture, OpenCL 2.0 support, three 4K res. displays at 60 Hz and many more. Find out full features at: https://pro.radeon.com/en-us/product/wx-series/radeon-pro-wx-2100/.
HPE ProLiant MicroServer Gen10 Performance - ultra micro tower - Opteron X3421 2.1 GHz - 16 GB - no HDD
Server - ultra micro tower
Server Scalability
1-way
1 x AMD Opteron X3421 / 2.1 GHz (, up to 3.4 GHz, (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
16 GB (installed) / 32 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s) (Marvell 88SE9230)
Hard Drive
No HDD
Optical Storage
No optical drive
1GbE
23 cm x 25.4 cm x 23.5 cm
6.5 kg
Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Ultra micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Processor / Chipset
CPU
AMD Opteron X3421
Clock Speed
2.1 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
16 GB / 32 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 16 GB
Hard Drive
No HDD
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Marvell 88SE9230
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA, DisplayPort
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x4 - low-profile (x1 mode)
1 x VGA , 3 x USB 2.0 (2 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (2 front, 2 rear) , 2 x DisplayPort
EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EMC, FCC CFR47 Part 15, ACPI 5.0, GB 9254, CNS 13438, K24, CISPR 32, EN 55032
Power supply
Power Provided
200 Watt
Operating System / Software
OS Certified
Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016
23 cm
25.4 cm
23.5 cm
6.5 kg
10 °C
35 °C
10 - 90% (non-condensing)
