The HP ProLiant MicroServer Gen8 is a small, quiet, and stylishly designed server that is ideal as a first server solution for small businesses. With a form factor that is easy to use and service, it helps small businesses drive down their expenses while improving productivity, efficiency, and security.
Simplified IT management with built-in Gen8 technologies
HP ProLiant MicroServer Gen8 comes with HP iLO4, providing access to innovations like Intelligent Provisioning for quick and simple installation and setup. Instant out-of-box server set up and deployment. Embedded remote management technology reduces on-site server administration and travel expenses. Continuous, proactive health monitoring ensures faster and more accurate problem resolution. -
Hassle-free serviceability maximizing uptime and productivity
Tool-less access to hard drives, memory, and PCI slots for simple installation or upgrade. Two up-front USB ports allow for easy deployment. iLO essentials license provides ability to connect media from your client device to your server and receive email alerts regarding server events. -
Unique server design ideal for small offices
Personalize your MicroServer with the front bezel faceplate kit. Small, quiet, energy efficient, and can be placed anywhere. Stylish blue LED light bar for at-a-glance system health status. Stackable managed switch creates clean, elegant look for networking and compute.
- HPE ProLiant MicroServer Gen8 - ultra micro tower - Xeon E3-1220LV2 2.3 GHz - 8 GB
- Server - ultra micro tower
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1220LV2 / 2.3 GHz (3.5 GHz) (Dual-Core)
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 8 GB (installed) / 16 GB (max) DDR3 SDRAM - ECC
- Storage Controller
- SATA (SATA 6Gb/s) (HP Dynamic Smart Array B120i)
- Hard Drive
- No HDD
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 22.97 cm x 24.51 cm x 23.24 cm
- 6.8 kg
- Limited warranty - parts - 1 year
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Ultra micro tower
- 1-way
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
Processor / Chipset
- CPU
- Intel Xeon E3-1220LV2 / 2.3 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C204
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, HP SmartMemory
- Configuration Features
- 1 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B120i
- Channel Qty
- 5
- RAID Level
- RAID 0, RAID 1, RAID 10
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Integrated
- Interface (Bus) Type
- PCI Express x1
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 4 (free) x internal 3.5" LFF
- Slots
- 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x VGA , 5 x USB 2.0 (2 front, 2 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO , 2 x USB 3.0
- Setup Password
- ACPI 2.0b, FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438
- Power supply
- Nominal Voltage
- Power Provided
- 150 Watt
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 22.97 cm
- 24.51 cm
- 23.24 cm
- 6.8 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
