HPE ProLiant Micro Server Gen10 Quad Core Opteron X3421 8GB
Quicklinx: DV16WS00 Mfr#: P04923-421
Case Style: Tower
Processor Type: Opteron
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 8GB
  • Opteron
£421.69 ex VAT
£506.02 inc VAT
The HPE ProLiant MicroServer Gen10 delivers an affordable compact entry level server specifically designed for small offices, home offices, or small business environments.
HPE ProLiant MicroServer Gen10 - ultra micro tower - Opteron X3421 2.1 GHz - 8 GB
Server - ultra micro tower
Region: EMEA
Server Scalability
1-way
1 x AMD Opteron X3421 / 2.1 GHz (3.4 GHz) (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - ECC
Storage Controller
SATA (SATA 6Gb/s) (Marvell 88SE9230)
Server Storage Bays
Non-hot-swap
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
OS Provided
ClearOS
23 cm x 25.4 cm x 23.5 cm
6.5 kg
Limited warranty - parts and labour - 1 year - on-site
Server
Product Form Factor
Ultra micro tower
Server Scalability
1-way
Internal Bays Qty
4
Front Accessible Bays Qty
1
Region: EMEA
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
No HDD
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Marvell 88SE9230
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Broadcom BCM5720
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x internal 3.5" LFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x4 - low-profile (x1 mode)
1 x VGA , 3 x USB 2.0 (2 rear, 1 internal) , 2 x LAN (Gigabit Ethernet) , 4 x USB 3.0 (2 front, 2 rear)
8 GB USB flash drive
ICES-003, EN55024, EMC, FCC CFR47 Part 15, ACPI 5.0, GB 9254, CNS 13438, EN61000-3-2, EN61000-3-3, K24, CISPR 32, EN 55032
Power supply
Nominal Voltage
Power Provided
200 Watt
Operating System / Software
OS Provided
ClearOS
23 cm
25.4 cm
23.5 cm
6.5 kg
10 °C
35 °C
10 - 90% (non-condensing)
Case Style: Tower
Brand: HPE
Price Range Ex VAT: 300 - 500
