Traditionally, mission-critical RAS (Reliability, Availability and Serviceability) features have been associated with RISC (Reduced Instruction Set Computing) systems. HP has designed an eco-system of RAS functionalities that has raised the bar for the HP ProLiant DL580 G7 Server series. The DL580 G7 continues to deliver best-in-class HP performance, manageability, and reliability features with the latest Intel processor technology and it is the ideal choice for customers that are ready to deploy large databases that require scale-up compute processing, large memory and I/O intensive applications.
Outstanding Performance and Scalability
Flexible technologies provides customer choice in networking with either a Broadcom or Qlogic solution.I/O expansion capabilities, the latest 10 core Intel processors, expandable DDR3 memory enables growing scaling up IT infrastructure as the business grows.The HP 4S architecture, new memory landscape of 2TB, 10Gb NIC upgrade option, up to 11 I/O slots and industry leading management solutions make this system ideal for virtualization.High performing Intel Xeon processor E7-4800 and 7500 series, faster memory access, higher network and I/O bandwidths enables the DL580 G7 for critical applications and workloads. -
Advanced Reliability and Availability
Double Device Data Correction - DDDC (Ready), this feature extends the capability to withstand failures in two x4 DRAM devices. DDDC can fix both single-and double-DRAM device memory errors.Standard hot plug redundant fans (3+1) and common-slot power supplies add high availability in the system.The latest flash backed write cache technology provides indefinite cache data retention as compared to two days retention with battery backed write cache in earlier generations.HP Insight Control helps administrators manage health proactively and in addition to new features like HP Memory Quarantine (which requires OS support), based on Intel's Machine Check Architecture (MCA) recovery, it empowers the DL580 G7 to be more resistant to errors in virtual environments. -
Industry Leading Management Solution
HP Insight Control measures, meters and caps power usage on individual and groups of servers to optimize power usage, driving significant gains to data center capacity.HP Insight Control now provides the ability to watch recorded boot and failure sequences, remote power on and power off, thereby enabling customers to dramatically reduce troubleshooting time, cost, and travel expenses. Functionality is provided by iLO Advanced.With HP Insight Control, you can reduce unplanned downtime by up to 77%. -
HP Converged Infrastructure Approach
HP is the only company to offer a full portfolio of standards-based, integrated solutions and services developed specifically to solve the complexities of the data center.By simplifying, integrating and automating technology, Converged Infrastructure accelerates outcomes that matter with: faster time to revenue; lower acquisition and implementation costs; flexibly respond to business changes and lower risks.
- HPE ProLiant DL580 G7 Base - rack-mountable - Xeon E7-4807 1.86 GHz - 64 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, USB port control
- Height (Rack Units)
- 4U
- Localisation
- Region: Europe
- Server Scalability
- 4-way
- Processor
- 2 x Intel Xeon E7-4807 / 1.86 GHz (6-core)
- Processor Socket
- LGA1567 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Smart Cache
- Cache Memory
- 36 MB L3 Cache
- Cache Per Processor
- 18 MB
- RAM
- 64 GB (installed) / 2 TB (max) - DDR3 SDRAM - Advanced ECC - PC3-10600
- Storage Controller
- RAID (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD
- Graphics Controller
- ATI ES1000
- Video Memory
- 64 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 48.3 cm x 70 cm x 17.6 cm
- 30 kg
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 4U
- 4-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E7-4807
- Clock Speed
- 1.86 GHz
- Number of Cores
- 6-core
- 64-bit Computing
- CPU Qty
- 2
- Max CPU Qty
- 4
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1567 Socket
- Chipset Type
- Intel 7500
Cache Memory
- Installed Size
- L3 Cache - 36 MB
- 18 MB
RAM
- Installed Size
- 64 GB / 2 TB (max)
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 64 (Total) / 56 (empty)
- Registered, Memory Mirroring, Online Spare Memory
- Configuration Features
- 8 x 8 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 3Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P410i with 512MB FBWC
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- Buffer Size
- 512 MB
Optical Storage
- DVD-ROM DVD - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- ATI ES1000
- Video Memory
- 64 MB
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x8
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP NC375i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 3
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 2 (total) / 2 (free) x PCIe 2.0 x16 - full-length, full-height (x8 mode) , 3 (total) / 3 (free) x PCIe 2.0 x8 - full-length, full-height (x4 mode)
- 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0 (2 front, 2 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 2 x display / video (1 front, 1 rear)
- Administrator password, power-on password, keyboard password, serial port I/O control, USB port control
- ACPI 2.0, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Installed Qty
- 2
- Max Supported Qty
- 4
- Voltage Required
- Power Provided
- 1200 Watt
Operating System / Software
- OS Certified
- SunSoft Solaris, SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
- 48.3 cm
- 70 cm
- 17.6 cm
- 30 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
