HPE ProLiant DL385 Gen10 AMD 8-Core EPYC 7251 16GB
Quicklinx: F8LPWS00 Mfr#: P05887-B21
Do you need a platform purpose-built to address your virtualized and memory-centric workloads? This platform has been designed with the security you need and the flexibility you require to accommodate demanding enterprise workloads. The HPE ProLiant DL385 Gen10 server delivers a low cost virtual machine with superior security.
  • Security innovations
    HPE ProLiant DL385 Gen10 server has security protection built in across the server lifecycle. Secure recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.
  • Flexible design
    HPE ProLiant DL385 Gen10 server has an adaptable chassis, including modular drive bays. This server supports a wide range of operating systems making it suitable for many environments.
HPE ProLiant DL385 Gen10 Solution - rack-mountable - EPYC 7251 2.1 GHz - 16 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x AMD EPYC 7251 / 2.1 GHz (, up to 2.9 GHz, (8-core)
Cache Memory
32 MB L3 Cache
Cache Per Processor
32 MB
RAM
16 GB (installed) / 1 TB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
1GbE
Power Redundancy
Optional
Software Included
HPE Server UEFI, HPE iLO Advanced, HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
44.55 cm x 67.94 cm x 8.73 cm
14.9 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel, battery
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
AMD EPYC 7251
Clock Speed
2.1 GHz
Max Turbo Speed
2.9 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 32 MB
Cache Per Processor
32 MB
RAM
Installed Size
16 GB / 1 TB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
32 (Total) / 31 (empty)
Registered, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
1 x 16 GB
RAM Supported
PC4-20800 - 1 TB registered , PC4-20800 - 4 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
PCI Express 2.0 x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HPE iLO - Type A (1 in front) , 1 x HPE iLO - RJ-45 (1 rear) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 1 x VGA (1 rear)
HPE Easy Install Rails, 4 standard fans
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
67.94 cm
8.73 cm
14.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
37 dBA
Internal Hard Drives (7)
F8LP HPE 1TB 6G SATA 7.2K 2.5IN SFF In Stock £406.28
F8LP HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD In Stock £500.78
F8LP HPE 300GB SAS 10K SFF SC DS-STOCK In Stock £124.49
F8LP HPE 300GB SAS 15K SFF SC DS-Stock In Stock £155.29
F8LP HPE 600GB SAS 10K SFF SC DS HDD In Stock £169.57
F8LP HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £191.25
F8LP HPE 600GB SAS 15K SFF SC DS HDD In Stock £223.08
Other bundles (2)
F8LP HPE Ethernet 1GB 4-Port Adapter In Stock £47.64
F8LP HPE 96W Smart Storage Battery In Stock £62.94
