HPE ProLiant DL385 Gen10 AMD 24-Core EPYC 7401 32GB
Quicklinx: F8LSWS00 Mfr#: 878720-B21
Case Style: Rack-mountable
Processor Type: EPYC
Hard Disk Capacity: 0GB
Processor Speed: 2GHz
Installed Memory: 32GB
£3,046.62 ex VAT
£3,655.94 inc VAT
Do you need a platform purpose-built to address your virtualized and memory-centric workloads? Try something EPYC . Hewlett Packard Enterprise is extending the worlds' most secure industry standard servers to include the HPE ProLiant DL385 Gen10 Server, utilizing the new AMD EPYC 7000 Series processors. This platform has been designed with the security you need and the flexibility you require to accommodate the most demanding enterprise workloads. With up to 64 cores, up to 32 DIMMs, or 4 TB memory capacity and support for up to 24 NVMe drives, the HPE ProLiant DL385 Gen10 Server delivers a low cost virtual machine (VM) with unprecedented security.
  • Security Innovations
    HPE ProLiant DL385 Gen10 Server has security protection built in across the server life cycle starting with Silicon Root of Trust. Only Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon.Millions of lines of firmware code run before server operating system boots. What's more, with Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.The AMD EPYC processor provides several security related features, including AMD secure processor, secure memory encryption (SME), and secure encrypted virtualization (SEV). These features are used to help enable key security functionality including Secure Root-of-Trust, Secure Run, and Secure Move.
  • Flexible Design
    HPE ProLiant DL385 Gen10 Server has an adaptable chassis, including the modular drive bays that can be configured with up to 30 SFF, up to 19 LFF or up to 24 NVMe drive options along with support for up to 3 double wide GPU options.HPE Smart Array S100i Software RAID ships standard for embedded m.2 boot, and the redesigned HPE Smart Array Essential and Performance RAID Controllers for performance or additional features including the ability to operate in both SAS and HBA mode.Along with an embedded 4x1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters which offer a choice of networking bandwidth (1GbE to 4x10GbE) and fabric so you can adapt and grow to changing business needs.This server supports a wide range of operating systems making it suitable for most environments.
  • World-class Performance
    HPE ProLiant DL385 Gen10 Server supports industry standard technology leveraging the AMD EPYC 7000 Series Processor with up to 32 cores, 12 Gb SAS and 4.0 TB of HPE DDR4 SmartMemory.Supports up to three double wide or five single wide graphic processing units (GPUs) for workload acceleration.
  • Proven Industry Leading Services and Ease of Deployment
    HPE ProLiant DL385 Gen10 Server comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an optimal solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE Financial Services helps you transform to a digital business with financing option and trade-in opportunities that align to your business goals.
HPE ProLiant DL385 Gen10 Base - rack-mountable - EPYC 7401 2 GHz - 32 GB
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x AMD EPYC 7401 / 2 GHz (3 GHz) (24-core)
Cache Memory
64 MB L3 Cache
Cache Per Processor
64 MB
RAM
32 GB (installed) / 1 TB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
GigE
Power Redundancy
Optional
44.55 cm x 67.94 cm x 8.73 cm
14.9 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel, battery
Server Scalability
2-way
Hot-Swap Bays Qty
24
Region: Worldwide
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
24-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 64 MB
Cache Per Processor
64 MB
RAM
Installed Size
32 GB / 1 TB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
32 (Total) / 30 (empty)
Registered, HPE SmartMemory
Configuration Features
2 x 16 GB
RAM Supported
PC4-20800 - 1 TB registered , PC4-20800 - 4 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, 1ADM, 10ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
PCI Express 2.0 x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331FLR
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external , 24 (total) / 24 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 1 (free) x CPU , 32 (total) / 30 (free) x DIMM 288-pin
1 x HP iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HP iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
Cable management arm, HPE Easy Install Rails, 4 standard fans
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
94%
Operating System / Software
Software
HPE Server UEFI, HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
67.94 cm
8.73 cm
14.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
31 dBA
Brand: HPE
Price Range Ex VAT: 1500+
