HPE ProLiant DL385 Gen10 AMD 16-Core EPYC 7351 32GB
Quicklinx: F8LRWS00 Mfr#: P09707-B21
Case Style: Rack-mountable
Processor Type: EPYC
Hard Disk Capacity: 0GB
Processor Speed: 2.4GHz
Installed Memory: 32GB
Hurry, only 1 left in stock!
£2,352.12 ex VAT
£2,822.54 inc VAT
Do you need a platform purpose-built to address your virtualized and memory-centric workloads? This platform has been designed with the security you need and the flexibility you require to accommodate demanding enterprise workloads. The HPE ProLiant DL385 Gen10 server delivers a low cost virtual machine with superior security.
  • Security innovations
    HPE ProLiant DL385 Gen10 server has security protection built in across the server lifecycle. Secure recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.
  • Flexible design
    HPE ProLiant DL385 Gen10 server has an adaptable chassis, including modular drive bays. This server supports a wide range of operating systems making it suitable for many environments.
HPE ProLiant DL385 Gen10 Solution - rack-mountable - EPYC 7351 2.4 GHz - 32 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x AMD EPYC 7351 / 2.4 GHz (16-core)
Cache Memory
64 MB L3 Cache
Cache Per Processor
64 MB
RAM
32 GB (installed) / 4 TB (max) - DDR4 SDRAM - ECC - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
GigE
Power Redundancy
Optional
44.54 cm x 73.02 cm x 9.73 cm
14.9 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Led panel, battery
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 64 MB
Cache Per Processor
64 MB
RAM
Installed Size
32 GB / 4 TB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2600 MHz
Rated Memory Speed
2600 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
32 (Total) / 30 (empty)
Registered, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
2 x 16 GB
RAM Supported
PC4-20800 - 1 TB registered , PC4-20800 - 4 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
PCI Express 2.0 x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HP iLO (1 in front) , 1 x HP iLO (1 rear) , 4 x LAN (Gigabit Ethernet) (4 rear) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 1 x VGA (1 rear)
HPE Easy Install Rails
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
Operating System / Software
Software
HPE Server UEFI, HPE iLO Advanced, HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
44.54 cm
73.02 cm
9.73 cm
14.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
37 dBA
Brand: HPE
Price Range Ex VAT: 1500+
