Do you need a platform purpose-built to address your virtualized and memory-centric workloads? Try something EPYC . Hewlett Packard Enterprise is extending the worlds' most secure industry standard servers to include the HPE ProLiant DL385 Gen10 Server, utilizing the new AMD EPYC 7000 Series processors. This platform has been designed with the security you need and the flexibility you require to accommodate the most demanding enterprise workloads. With up to 64 cores, up to 32 DIMMs, or 4 TB memory capacity and support for up to 24 NVMe drives, the HPE ProLiant DL385 Gen10 Server delivers a low cost virtual machine (VM) with unprecedented security.
Security Innovations
HPE ProLiant DL385 Gen10 Server has security protection built in across the server life cycle starting with Silicon Root of Trust. Only Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon.Millions of lines of firmware code run before server operating system boots. What's more, with Runtime Firmware Validation, enabled by HPE iLO Advanced Premium Security Edition, the server firmware is checked every 24 hours verifying validity and credibility of essential system firmware.Secure Recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.The AMD EPYC processor provides several security related features, including AMD secure processor, secure memory encryption (SME), and secure encrypted virtualization (SEV). These features are used to help enable key security functionality including Secure Root-of-Trust, Secure Run, and Secure Move. -
Flexible Design
HPE ProLiant DL385 Gen10 Server has an adaptable chassis, including the modular drive bays that can be configured with up to 30 SFF, up to 19 LFF or up to 24 NVMe drive options along with support for up to 3 double wide GPU options.HPE Smart Array S100i Software RAID ships standard for embedded m.2 boot, and the redesigned HPE Smart Array Essential and Performance RAID Controllers for performance or additional features including the ability to operate in both SAS and HBA mode.Along with an embedded 4x1GbE, you have a choice of HPE FlexibleLOM or PCIe standup adapters which offer a choice of networking bandwidth (1GbE to 4x10GbE) and fabric so you can adapt and grow to changing business needs.This server supports a wide range of operating systems making it suitable for most environments. -
World-class Performance
HPE ProLiant DL385 Gen10 Server supports industry standard technology leveraging the AMD EPYC 7000 Series Processor with up to 32 cores, 12 Gb SAS and 4.0 TB of HPE DDR4 SmartMemory.Supports up to three double wide or five single wide graphic processing units (GPUs) for workload acceleration. -
Proven Industry Leading Services and Ease of Deployment
HPE ProLiant DL385 Gen10 Server comes with a complete set of HPE Pointnext services, delivering confidence, reducing risk and helping customers realize agility and stability.Services from HPE Pointnext simplify all stages of the IT journey. Advisory and Transformation Services professionals understand customer challenges and design an optimal solution. Professional Services enables rapid deployment of solutions and Operational Services provides ongoing support.Services provided under Operational Services include: HPE Flexible Capacity, HPE Datacenter Care, HPE Infrastructure Automation, HPE Campus Care, HPE Proactive Services and multi-vendor coverage.HPE Financial Services helps you transform to a digital business with financing option and trade-in opportunities that align to your business goals.
- HPE ProLiant DL385 Gen10 Performance - rack-mountable - EPYC 7451 2.3 GHz - 64 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 2 x AMD EPYC 7451 / 2.3 GHz (, up to 3.2 GHz, (24-core)
- Cache Memory
- 128 MB L3 Cache
- Cache Per Processor
- 64 MB
- RAM
- 64 GB (installed) / 1 TB (max) - DDR4 SDRAM - ECC - PC4-20800
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- DVD-Writer
- Card Reader
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- Software Included
- HPE Server UEFI, HPE iLO Standard with Intelligent Provisioning, HPE OneView Standard (free download)
- 44.55 cm x 67.94 cm x 8.73 cm
- 14.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Led panel
- 2-way
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- AMD EPYC 7451
- Clock Speed
- 2.3 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 24-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- L3 Cache - 128 MB
- 64 MB
RAM
- Installed Size
- 64 GB / 1 TB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-20800
- Form Factor
- DIMM 288-pin
- Slots
- 32 (Total) / 30 (empty)
- Registered, HPE SmartMemory
- Configuration Features
- 2 x 32 GB
- RAM Supported
- PC4-20800 - 1 TB registered , PC4-20800 - 4 TB Load-Reduced
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, 1ADM, 10ADM
- Buffer Size
- 2 GB
Optical Storage
- DVD-RW DVD-Writer
Card Reader
- Card reader
- Supported Flash Memory Cards
- microSD
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express 2.0 x4
- Ethernet Ports
- 4 x Gigabit Ethernet, 2 x 25 Gigabit Ethernet
- Ethernet Controller
- HPE 331i, HPE 640FLR
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 0 (free) x FlexibleLOM , 2 (total) / 2 (free) x PCIe 3.0 x16 - half-length, full-height , 4 (total) / 4 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal) , 2 (total) / 0 (free) x CPU , 32 (total) / 30 (free) x DIMM 288-pin
- 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 2 x LAN (25Gigabit Ethernet) (SFP28) , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
- Included Accessories
- Cable management arm, HPE Easy Install Rails, 4 standard fans
- AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 2
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 800 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Operating System / Software
- Software
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 44.55 cm
- 67.94 cm
- 8.73 cm
- 14.9 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 31 dBA
Internal Hard Drives (6)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £222.98 |
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD | In Stock | £222.86 |
HPE 300GB SAS 10K SFF SC DS-STOCK | In Stock | £124.49 |
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £155.58 |
HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s | In Stock | £191.39 |
HPE 600GB SAS 15K SFF SC DS HDD | In Stock | £223.08 |
Other bundles (2)
HPE Ethernet 1GB 4-Port Adapter | In Stock | £47.64 |
HPE 96W Smart Storage Battery | In Stock | £62.94 |
