Does your data center face the challenges of keeping pace with data growth while effectively managing and protecting your data? Do you need a cost-effective, enterprise-class server that can grow with you? The HP ProLiant DL380e Gen8 Server delivers essential performance for data centers to meet their compute and storage needs today with scalability to grow as business requirements change. With improved performance, security and efficiency, the HP ProLiant DL380e Gen8 Server helps businesses stay ahead of data growth quickly and easily. Its embedded management tools simplify server administration and automate mundane IT tasks, saving businesses valuable time and resources. Proactive, automated service support ensures quick resolution to issues. The HP ProLiant DL380e Gen8 provides a cost-effective solution for data centers requiring essential compute and storage today with changing requirements over time.
Essential Performance and Configuration Flexibility to Accommodate Data Growth
The HP ProLiant DL380e Gen8 Server provides a wide selection of controllers, drives, I/O expansion, and rear drive options for customers to meet their varying storage requirements today, with scalability to extend their solution tomorrow in a cost-effective manner.Supports up to two Intel Xeon E5-2400 v2 processors offering improved performance, efficiency and security.Provides flexible configuration for customers who need large storage capacity as well as those who want to benefit from the high performance storage controllers. Supports up to twenty-seven (27) 2.5-inch SFF or fourteen (14) 3.5-inch LFF SAS, SATA, or SSD drives.Increase your storage capacity and stay ahead of data growth with HP Dynamic Workload Acceleration, which converges storage, compute, and I/O to turbo-charge performance and eliminate bottlenecks. -
High Availability and Efficiency for the Dense Storage Environment
The HP ProLiant DL380e Gen8 Server provides a range of features that ensure data security and high availability. It includes ECC memory protection, TPM, secured bezel, as well as redundant power supply and fan options.Latest HP Smart Array Controllers are designed to maximize data availability, performance and capacity.HP SmartMemory, with speeds up to 1600 MHz at low voltage, now prevents data loss and downtime with enhanced error handling, while improving performance and power efficiency. Maximum memory supported is 384 GB.HP Common Slot Power Supplies provide 96% server power efficiency to reduce power consumption, while HP Automated Energy Optimization reclaims space, power, and cooling resources to extend your data center capacity.ENERGY STAR qualified server configurations illustrate a continued commitment to helping customers conserve energy and save money. -
Built-in Innovations that Simplify Management and Free Up Limited IT Resources
With embedded management tools, the HP ProLiant DL380e Gen8 Server simplifies server management and maintenance tasks enabling quick and simple deployment (HP Intelligent Provisioning), system health monitoring (HP Active Health System), and ease of firmware updates (HP Smart Update Manager).HP Smart Storage Administrator provides a single display screen for management and configuration of all HP Smart Storage products and solutions.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HP SmartDrives, HP Smart Socket guides, rail kit options, and tool-less access to components. -
Proactive Service and Support to Redefine Service Experience
The HP ProLiant DL380e Gen8 Server offers HP proactive support services, which integrate industry leading performance, uptime, and productivity into a personalized, simplified support experience.HP Insight Online with HP Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.Through HP ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.
- HPE ProLiant DL380e Gen8 Base - rack-mountable - Xeon E5-2407 2.2 GHz - 8 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, serial port I/O control
- Height (Rack Units)
- 2U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2407 / 2.2 GHz (Quad-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel QuickPath Interconnect
- Cache Memory
- 10 MB L3 Cache
- Cache Per Processor
- 10 MB
- RAM
- 8 GB (installed) / 192 GB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- RAID (SATA 6Gb/s) - PCIe 2.0 x4 (HP Dynamic Smart Array B320i with 512MB FBWC)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.55 cm x 74.94 cm x 8.75 cm
- 14 kg
- Limited warranty - parts - 3 years , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 2U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2407
- Clock Speed
- 2.2 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- L3 Cache - 10 MB
- 10 MB
RAM
- Installed Size
- 8 GB / 192 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 12 (Total) / 10 (empty)
- Low-voltage
- Configuration Features
- 2 x 4 GB
- RAM Supported
- PC3-12800 - 192 GB registered , PC3-10600 - 384 GB Load-Reduced , PC3-10600 - 96 GB unbuffered - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - integrated - PCIe 2.0 x4
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HP Dynamic Smart Array B320i with 512MB FBWC
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
- Buffer Size
- 512 MB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Integrated
- Interface (Bus) Type
- PCI Express 2.0 x2
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 366i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
- Bays
- 8 (total) / 8 (free) x hot-swap 3.5" LFF , 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 12 (total) / 10 (free) x memory - LRDIMM 240-pin DIMM 240-pin , 2 (total) / 1 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode) , 1 (total) / 1 (free) x SD card
- 1 x serial , 2 x display / video (1 front, 1 rear) , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
- Administrator password, power-on password, serial port I/O control
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, BSMI CNS 13438, GB 4943
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 460 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 92%
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- 44.55 cm
- 74.94 cm
- 8.75 cm
- 14 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
