The HPE ProLiant DL380 Gen10 server delivers great security, performance and expandability. It's securely designed to reduce costs and complexity.
- HPE ProLiant DL380 Gen10 SMB - rack-mountable - Xeon Silver 4208 2.1 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4208 / 2.1 GHz (, up to 3.2 GHz, (8-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB L3 Cache
- Cache Per Processor
- 11 MB
- RAM
- 16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array P408i-a)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Software Included
- HPE Server UEFI
- 44.54 cm x 67.94 cm x 8.73 cm
- 14.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Battery
- 2-way
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon Silver 4208
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.2 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 11 MB
- 11 MB
RAM
- Installed Size
- 16 GB / 1.5 TB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2933 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory, 6-channel memory architecture
- Configuration Features
- 1 x 16 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HPE 331i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
- 4 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear) , 8 x SATA-600 / SAS 3.0 , 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal)
- Included Accessories
- Cable management arm, 4 standard fans, SFF Easy install rails
- AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- Power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Certified
- CentOS, Microsoft Windows Server 2012 R2, VMware vSphere 6.0 (ESXi), SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, VMware vSphere 6.5, SuSE Linux Enterprise Server 12 SP2, ClearOS
- Software
- HPE Server UEFI
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 44.54 cm
- 67.94 cm
- 8.73 cm
- 14.9 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
Warranty Packs (1)
Internal Hard Drives (1)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £222.98 |
Other bundles (7)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.09 |
HPE HP Ethernet 10Gb 2P 530SFP+ Adapter | In Stock | £211.98 |
HPE Ethernet 1GB 4-Port Adapter | In Stock | £47.64 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
HPE 96W Smart Storage Battery | In Stock | £62.94 |
HPE DL38X GEN10 Universal Media Bay | In Stock | £32.82 |
