The HPE ProLiant DL380 Gen10 server is securely designed to reduce costs and complexity. HPE ProLiant servers offer superior levels of performance for databases and analytic workloads. Run everything from basic to mission-critical applications, and deploy with confidence.
Flexible design making your investment expand as your business needs grow
The HPE ProLiant DL380 Gen10 server has an adaptable chassis, including an HPE modular drive bay. It delivers superior levels of performance and data resiliency for databases and analytic workloads. -
Security innovations
Hewlett Packard Enterprise offers servers with major firmware anchored directly into the silicon. With security protection built in across the server lifecycle. Secure recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.
- HPE ProLiant DL380 Gen10 Performance - rack-mountable - Xeon Silver 4114 2.2 GHz - 32 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 2U
- Localisation
- Region: Worldwide
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
- Processor Socket
- FCLGA3647 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 13.75 MB L3 Cache
- Cache Per Processor
- 13.75 MB
- RAM
- 32 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC - PC4-21333
- Storage Controller
- RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Video Memory
- 16 MB
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44.55 cm x 73.07 cm x 8.74 cm
- 14.76 kg
- Manufacturer Selling Program
- HPE Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
- Server
- Product Form Factor
- Rack-mountable - 2U
- Built-in Devices
- Battery
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon Silver 4114
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- FCLGA3647 Socket
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- L3 Cache - 13.75 MB
- 13.75 MB
RAM
- Installed Size
- 32 GB / 1.5 TB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
- Configuration Features
- 1 x 32 GB
- RAM Supported
- 3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - PCIe 3.0 x8
- Controller Interface Type
- SATA 6Gb/s / SAS 12Gb/s
- Storage Controller Name
- HPE Smart Array P408i-a
- Channel Qty
- 8
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
- Buffer Size
- 2 GB
Storage Controller (2nd)
- 1 x SATA
- SATA 6Gb/s
- HPE Smart Array S100i SR Software
- Channel Qty
- 14
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 4 x Gigabit Ethernet
- Ethernet Controller
- HP 331i
- Data Link Protocol
- Remote Management Protocol
- SNMP 3, IPMI 2.0, SMASH CLP
- Remote Management Controller
- Integrated Lights-Out 5
- Wake on LAN (WoL), PXE support
- Bays
- 1 external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
- 1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
- Included Accessories
- RAID Battery Backup Unit, HPE Easy Install Rails, 4 standard fans, CPU standard heatsink
- AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
- HPE Smart Buy
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 800 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 2.1
- 44.55 cm
- 73.07 cm
- 8.74 cm
- 14.76 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 31 dBA
Warranty Packs (1)
Internal Hard Drives (7)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £222.98 |
HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD | In Stock | £222.86 |
HPE 300GB SAS 10K SFF SC DS-STOCK | In Stock | £124.49 |
HPE 300GB SAS 15K SFF SC DS-Stock | In Stock | £155.58 |
HPE 600GB SAS 10K SFF SC DS HDD | In Stock | £169.57 |
HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s | In Stock | £191.39 |
HPE 600GB SAS 15K SFF SC DS HDD | In Stock | £223.08 |
Other bundles (7)
HPE HP Ethernet 1Gb 4-port 331T Adapter | In Stock | £81.28 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.09 |
HPE HP Ethernet 10Gb 2P 530SFP+ Adapter | In Stock | £211.98 |
HPE Ethernet 1GB 4-Port Adapter | In Stock | £47.64 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
HPE 96W Smart Storage Battery | In Stock | £62.94 |
HPE DL38X GEN10 Universal Media Bay | In Stock | £32.82 |
