HPE ProLiant DL380 Gen10 Intel Xeon Silver 4110 16GB
Quicklinx: F7NFWS00 Mfr#: P05524-B21
The HPE ProLiant DL380 Gen10 server delivers great security, performance and expandability. It's securely designed to reduce costs and complexity.
HPE ProLiant DL380 Gen10 Solution - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - no HDD
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC - PC4-21333
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
1GbE
Power Redundancy
44.55 cm x 73.07 cm x 8.74 cm
14.76 kg
Manufacturer Selling Program
HPE Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
1 x 16 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
1 x SATA
SATA 6Gb/s
Channel Qty
14
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HPE iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HPE iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
HPE Easy Install Rails, 4 standard fans, CPU standard heatsink, ClearOS/VM installer USB
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
HPE Smart Buy
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
500 Watt
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
73.07 cm
8.74 cm
14.76 kg
10 °C
35 °C
8 - 90% (non-condensing)
Warranty Packs (1)
F7NF HPE Installation and Startup - installation / configuration 1 incident On-Site In Stock £1,212.69
Internal Hard Drives (7)
F7NF HPE 1TB 6G SATA 7.2K 2.5IN SFF In Stock £406.28
F7NF HPE 1TB 12G SAS 7.2K 2.5 MDL SC HDD In Stock £500.78
F7NF HPE 300GB SAS 10K SFF SC DS-STOCK In Stock £124.49
F7NF HPE 300GB SAS 15K SFF SC DS-Stock In Stock £155.29
F7NF HPE 600GB SAS 10K SFF SC DS HDD In Stock £169.57
F7NF HPE Hard drive 1.2 TB hot-swap 2.5" SFF SAS 12Gb/s In Stock £191.25
F7NF HPE 600GB SAS 15K SFF SC DS HDD In Stock £223.08
Other bundles (6)
F7NF HPE HP Ethernet 1Gb 4-port 331T Adapter In Stock £81.28
F7NF HPE HP Ethernet 1GB 2P 332T Adaptor In Stock £39.06
F7NF HPE Ethernet 1GB 4-Port Adapter In Stock £47.64
F7NF HPE Ethernet 1GB 4-Port 366T Adapter In Stock £164.89
F7NF HPE 96W Smart Storage Battery In Stock £62.94
F7NF HPE DL38X GEN10 Universal Media Bay In Stock £32.82
