HPE ProLiant DL380 Gen10 Intel Xeon Gold 6130 64GB
Quicklinx: F8LCWS00 Mfr#: P06423-B21
Case Style: Rack-mountable
Processor Type: Xeon Gold
Hard Disk Capacity: 0GB
Processor Speed: 2.1GHz
Installed Memory: 64GB
£3,261.44 ex VAT
£3,913.72 inc VAT
The HPE ProLiant DL380 Gen10 server delivers advanced security, performance and expandability. It is ideal for any server environment.
  • Flexible design
    The HPE ProLiant DL380 Gen10 server has an adaptable chassis, including an HPE modular drive bay. You will get incredible levels of performance and data resiliency for databases and analytic workloads.
  • Security innovations
    Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon. With security protection built in across the server lifecycle.
HPE ProLiant DL380 Gen10 Performance - rack-mountable - Xeon Gold 6130 2.1 GHz - 64 GB
Server - rack-mountable
Height (Rack Units)
2U
Region: Worldwide
Server Scalability
2-way
1 x Intel Xeon Gold 6130 / 2.1 GHz (16-core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology
Cache Memory
22 MB L3 Cache
Cache Per Processor
22 MB
RAM
64 GB (installed) / 3 TB (max) - DDR4 SDRAM - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (SATA 6Gb/s) (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Video Memory
16 MB
GigE
Power Redundancy
44.55 cm x 73.07 cm x 8.74 cm
14.76 kg
Manufacturer Selling Program
HPE Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 22 MB
Cache Per Processor
22 MB
RAM
Installed Size
64 GB / 3 TB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
12 (Total) / 10 (empty)
Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
2 x 32 GB
RAM Supported
PC4-20800 - 3.072 TB Load-Reduced , PC4-20800 - 768 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
1 x SATA
SATA 6Gb/s
Channel Qty
14
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HP iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HP iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
HP Easy Install Rail kit, 4 standard fans, CPU standard heatsink
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
HPE Smart Buy
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
80 PLUS Certification
80 PLUS Platinum
ENERGY STAR Certified
ENERGY STAR Version
2.1
44.55 cm
73.07 cm
8.74 cm
14.76 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
31 dBA
Brand: HPE
Price Range Ex VAT: 1500+
