HPE ProLiant DL380 Gen10 Intel Xeon Gold 5118 64GB
Quicklinx: F1PMWS00 Mfr#: P06422-B21
Case Style: Rack-mountable
Processor Type: Xeon Gold
Hard Disk Capacity: 0GB
Processor Speed: 2.3GHz
Installed Memory: 64GB
Hurry, only 1 left in stock!
£2,425.80 ex VAT
£2,910.96 inc VAT
The HPE ProLiant DL380 Gen10 server delivers advanced security, performance and expandability. It is ideal for any server environment.
  • Flexible design
    The HPE ProLiant DL380 Gen10 server has an adaptable chassis, including an HPE modular drive bay. You will get incredible levels of performance and data resiliency for databases and analytic workloads.
  • Security innovations
    Hewlett Packard Enterprise offers industry standard servers with major firmware anchored directly into the silicon. With security protection built in across the server lifecycle.
HPE ProLiant DL380 Gen10 Performance - rack-mountable - Xeon Gold 5118 2.3 GHz - 64 GB
Server - rack-mountable
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon Gold 5118 / 2.3 GHz (3.2 GHz) (12-core)
Cache Memory
16.5 MB L3 Cache
Cache Per Processor
16.5 MB
RAM
64 GB (installed) / 3 TB (max) DDR4 SDRAM - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
Power Redundancy
Optional
44.54 cm x 67.94 cm x 8.73 cm
14.9 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 2U
Built-in Devices
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
12-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 16.5 MB
Cache Per Processor
16.5 MB
RAM
Installed Size
64 GB / 3 TB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
24 (Total)
RAM Supported
PC4-20800 3.072 TB Load-Reduced , PC4-20800 768 GB registered
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x FlexibleLOM , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
1 x HP iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 1 x HP iLO - RJ-45 (1 rear) , 1 x VGA (1 rear)
AES, FIPS 140-2, IPv6 Ready, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Installed Qty
2
Max Supported Qty
2
Nominal Voltage
Power Provided
800 Watt
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, VMware vSphere 6.0 (ESXi), SuSE Linux Enterprise Server 11 SP4, Microsoft Windows Server 2016, Red Hat Enterprise Linux 7.3, Red Hat Enterprise Linux 6.9, SuSE Linux Enterprise Server 12 SP2, ClearOS
44.54 cm
67.94 cm
8.73 cm
14.9 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
31 dBA
Brand: HPE
Price Range Ex VAT: 1500+
