HPE Proliant DL360e Gen8 SFF Intel Xeon E5-2407v2 8GB
Quicklinx: 9FZFWS00 Mfr#: 747090-421
  • Xeon
  • Red Hat Enterprise Linux
Are you constrained by budget, space and IT resources? Yet you need an enterprise-class server for your IT environment? The HP ProLiant DL360e Gen8 Server includes ample performance, storage and I/O features at a low acquisition cost for the value-focused customer. Hyperscale customers can take advantage of the dense 1U design, price-performance, and energy efficiency to scale out as their needs increase. Built-in intelligence simplifies server management, and a proactive service model automates service support, enabling businesses with limited IT resources to focus on more important tasks. The ProLiant DL360e Gen8 Server delivers performance, data security, and energy efficiency, providing an excellent value on your investment.
  • Essential Features For the IT Needs of Value-Focused Enterprises
    The HPE ProLiant DL360e Gen8 Server, with built-in technologies, addresses business requirements at low initial acquisition cost, delivering great value for investment.Supports up to two Intel Xeon E5-2400 v2 processors, offering improved performance, efficiency and security.HPE SmartMemory, with speeds up to 1600 MHz at low voltage, now prevents data loss and downtime with enhanced error handling, while improving performance and power efficiency. Maximum memory supported is 384 GB.Latest HPE Smart Array Controllers are designed to maximize data availability, performance and capacity.Network and I/O scalability are provided by 4x1 GbE network ports and two I/O slots.
  • Optimized Design, Efficiency and Scalability for Hyperscale Environments
    The HPE ProLiant DL360e Gen8 Server delivers an affordable solution in a dense 1U rack design that enables Hyperscale customers to scale out as their requirements increase.Embedded quad-port NIC, 2 PCIe slots, and 12 DIMM slots provide the internal expansion capabilities needed for distributed computing environments like Hadoop and NoSQL.HPE Common Slot Power Supplies provide 96% server power efficiency to reduce power consumption, while HPE Automated Energy Optimization reclaims space, power, and cooling resources to extend your data center capacity.ENERGY STAR qualified server configurations illustrate a continued commitment to helping customers conserve energy and save money.
  • Built-in Innovations that Simplify Management and Free Up Limited IT Resources
    With embedded management tools, the HPE ProLiant DL360e Gen8 Server simplifies server management and maintenance tasks, enabling quick and simple deployment (HPE Intelligent Provisioning), system health monitoring (HPE Active Health System), and ease of firmware updates (HPE Smart Update Manager).HPE Smart Storage Administrator provides a single display screen for management and configuration of all HPE Smart Storage products and solutions.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, "Easy Install" rail kit options, and tool-less access to components.
  • Proactive Service and Support to Redefine Service Experience
    The HPE ProLiant DL360e Gen8 Server offers HPE proactive support services, which integrate industry leading performance, uptime, and productivity into a personalized, simplified support experience.HPE Insight Online with HPE Insight Remote Support provides 24x7 remote monitoring and anywhere, anytime personalized access to your IT and support status.Through HPE ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.
HPE ProLiant DL360e Gen8 Base - rack-mountable - Xeon E5-2407V2 2.4 GHz - 8 GB - no HDD
Server - rack-mountable - administrator password, power-on password, serial port I/O control
Height (Rack Units)
1U
Region: Europe
Server Scalability
2-way
1 x Intel Xeon E5-2407V2 / 2.4 GHz (Quad-Core)
Processor Socket
LGA1356 Socket
Processor Main Features
Intel QuickPath Interconnect, Intel Smart Cache
Cache Memory
10 MB L3 Cache
Cache Per Processor
10 MB
RAM
8 GB (installed) / 192 GB (max) - DDR3 SDRAM - Advanced ECC - PC3L-12800
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (HP Dynamic Smart Array B320i with 512MB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE
Power Redundancy
Optional
43.46 cm x 69.9 cm x 4.32 cm
13.2 kg
Limited warranty - parts and labour - 1 year - on-site - response time: next business day , Limited warranty - parts - 3 years
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Front Accessible Bays Qty
1
Hot-Swap Bays Qty
8
Region: Europe
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA1356 Socket
Cache Memory
Installed Size
L3 Cache - 10 MB
Cache Per Processor
10 MB
RAM
Installed Size
8 GB / 192 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3L-12800
DIMM 240-pin
Slots
12 (Total) / 11 (empty)
Registered, low-voltage
Configuration Features
1 x 8 GB
RAM Supported
384 GB Load-Reduced - Advanced ECC , 192 GB registered - Advanced ECC , 96 GB unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Buffer Size
512 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express 2.0 x4
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HP 366i
Remote Management Protocol
SNMP, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x8 - low-profile (x4 mode) , 1 (total) / 1 (free) x SD card
2 x VGA (1 front, 1 rear) , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 7 x USB 2.0 (2 front, 4 rear, 1 internal)
HPE Easy Install Rails
Administrator password, power-on password, serial port I/O control
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
460 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
92%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
43.46 cm
69.9 cm
4.32 cm
13.2 kg
10 °C
35 °C
10 - 90% (non-condensing)
Sound Emission
33 dBA
9FZF C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
