HPE ProLiant DL360 Gen10 Intel Xeon Silver 4110 16GB
Quicklinx: F7N4WS00 Mfr#: P05520-B21
Does your data center need a secure, performance driven dense server that you can confidently deploy for virtualization, database, or high-performance computing? The HPE ProLiant DL360 Gen10 server delivers security, agility and flexibility without compromise.
  • Superior performance
    Achieve greater capacity with flexible drive configurations. The DL360 Gen10 offers enhanced performance, capacity, and reliability to meet various customer segments and workload requirements at the right economics.
  • Security innovations
    HPE technology protects your servers from attacks, detect potential intrusions and recover your essential server firmware securely. Secure recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised code.
HPE ProLiant DL360 Gen10 Solution - rack-mountable - Xeon Silver 4110 2.1 GHz - 16 GB - no HDD
Server - rack-mountable
Height (Rack Units)
1U
Region: Worldwide
Server Scalability
2-way
1 x Intel Xeon Silver 4110 / 2.1 GHz (, up to 3 GHz, (8-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 1.5 TB (max) - DDR4 SDRAM - Advanced ECC - PC4-21333
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) - PCIe 3.0 x8 (HPE Smart Array P408i-a); SATA (HPE Smart Array S100i SR Software)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
1GbE
Power Redundancy
Software Included
HPE Server UEFI
43.46 cm x 70.7 cm x 4.29 cm
13.04 kg
Manufacturer Selling Program
HPE Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day , Technical support - software application support - 90 days
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel, battery
Server Scalability
2-way
Hot-Swap Bays Qty
8
Region: Worldwide
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3 GHz
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C621
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 1.5 TB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank, slots 13 - 24 are available in two-processor configuration only, HPE SmartMemory
Configuration Features
1 x 16 GB
RAM Supported
3 TB Load-Reduced - ECC , 1.5 TB registered - ECC , 192 GB Non-Volatile - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - PCIe 3.0 x8
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Storage Controller (2nd)
SATA
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
FlexibleLOM
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external Universal Media Bay , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 0 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - three-quarter-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x8 - low-profile , 1 (total) / 1 (free) x microSD Card (internal)
1 x HPE iLO - Type A (1 in front) , 1 x HPE iLO - RJ-45 (1 rear) , 4 x LAN (Gigabit Ethernet) - RJ-45 (4 rear) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 1 x VGA (1 rear)
HPE Easy Install Rails, HPE standard heatsink, 5 x standard hot plug fans
Power cable
AES, FIPS 140-2, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
HPE Smart Buy
Power supply - hot-plug
Power Redundancy
Power Redundancy Scheme
1+1
Installed Qty
2
Max Supported Qty
2
Power Provided
500 Watt
Operating System / Software
Software
HPE Server UEFI
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
2.1
43.46 cm
70.7 cm
4.29 cm
13.04 kg
10 °C
35 °C
8 - 90% (non-condensing)
