HPE ProLiant DL325 Gen10 AMD EPYC 7351P 16GB
Quicklinx: F7N0WS00 Mfr#: P04651-B21
Case Style: Rack-mountable
Processor Type: EPYC
Hard Disk Capacity: 0GB
Processor Speed: 2.4GHz
Installed Memory: 16GB
£1,625.49 ex VAT
£1,950.58 inc VAT
Do you need a dense platform with built-in security and flexibility that addresses key applications such as virtualization and software-defined storage? The HPE ProLiant DL325 Gen10 offers an exceptional balance of processor, memory and I/O for virtualization and data intensive workloads.
  • Innovative design
    HPE ProLiant DL325 Gen10 has a dense chassis that accommodates several drive options. You can adapt and grow to changing business needs.
  • Security innovations
    Secure recovery allows server firmware to roll back to the last known good state or factory settings after detection of compromised server. Additional security options are available with TPM to avoid unauthorized access to the server and store artifacts used to authenticate the server platforms, while the intrusion detection kit logs and alerts when the server hood is removed for further protection.
HPE ProLiant DL325 Gen10 Performance - rack-mountable - EPYC 7351P 2.4 GHz - 16 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
1-way
1 x AMD EPYC 7351P / 2.4 GHz (16-core)
Processor Socket
Socket SP3
Cache Memory
64 MB L3 Cache
Cache Per Processor
64 MB
RAM
16 GB (installed) / 2 TB (max) - DDR4 SDRAM - PC4-20800
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (HPE Smart Array P408i-a)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Video Memory
16 MB
GigE
Power Redundancy
Optional
10.7 kg
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel, battery
Server Scalability
1-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Number of Cores
16-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
Socket SP3
Cache Memory
Installed Size
L3 Cache - 64 MB
Cache Per Processor
64 MB
RAM
Installed Size
16 GB / 2 TB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-20800
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
PC4-20800 - 2 TB Load-Reduced , PC4-20800 - 1 TB registered
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
Storage Controller Name
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60, RAID 1 ADM, RAID 10 ADM
Buffer Size
2 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD
Monitor
Monitor Type
None.
Graphics Controller
Video Memory
16 MB
Video Interfaces
VGA
Ethernet Ports
4 x Gigabit Ethernet
Ethernet Controller
HPE 331i
Remote Management Protocol
SNMP 3, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 5
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external , 8 (total) / 8 (free) x hot-swap 2.5" SFF
Slots
1 (total) / 1 (free) x FlexibleLOM - three-quarter-length, full-height (low-profile) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 (low-profile) , 1 (total) / 1 (free) x microSD Card (internal)
1 x HP iLO - Type A (1 in front) , 5 x USB 3.0 (1 front, 2 rear, 2 internal) , 4 x LAN (Gigabit Ethernet) (4 rear) , 1 x HP iLO (1 rear) , 1 x VGA (1 rear)
HPE Easy Install Rails, CPU standard heatsink, 5 x standard hot plug fans
AES, FIPS 140-2, Triple DES, IPv6 Ready, PCI DSS, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, WEEE 2002/95/EC, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
500 Watt
Operating System / Software
OS Certified
CentOS, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, SuSE Linux Enterprise Server 12 SP3, Red Hat Enterprise Linux 7.4, Red Hat Enterprise Linux 7.5, VMware vSphere 6.5 (ESXi) Update 2, VMware vSphere 6.7 (ESXi)
10.7 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
37 dBA
Brand: HPE
Price Range Ex VAT: 1500+
