The dense and compact HPE ProLiant DL20 server provides a unique blend of enterprise class capabilities & value. It offers outstanding configuration flexibility to cater to a wide variety of business requirements.
- HPE ProLiant DL20 Gen10 solution - rack-mountable - Xeon E-2134 3.5 GHz - 16 GB - no HDD
- Server - rack-mountable
- Height (Rack Units)
- 1U
- Localisation
- Region: Worldwide
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E-2134 / 3.5 GHz (, up to 4.5 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-21333
- Storage Controller
- RAID (SATA 6Gb/s) (HPE Smart Array S100i SR Software RAID)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 43.46 cm x 38.22 cm x 4.32 cm
- 7.88 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site - response time: next business day
- Server
- Product Form Factor
- Rack-mountable - 1U
- 1-way
- Hot-Swap Bays Qty
- 4
- Localisation
- Region: Worldwide
Processor / Chipset
- CPU
- Intel Xeon E-2134
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 4.5 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 16 GB / 64 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 16 GB
Hard Drive
- No HDD
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- HPE Smart Array S100i SR Software RAID
- Channel Qty
- 4
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
- Interface (Bus) Type
- PCI Express x2
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HPE 332i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Bays
- 1 (total) / 1 (free) x external 5.25" , 4 (total) / 4 (free) x hot-swap 2.5" SFF
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (x16 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - low-profile (x8 mode)
- 1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x LAN (Gigabit Ethernet) / HP iLO , 5 x USB 3.0 (2 front, 2 rear, 1 internal)
- Included Accessories
- HPE Short Friction Rail kit
- AES, FIPS 140-2, TLS v1.2, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1, Redfish API, UEFI
- Power supply
- Power Redundancy
- Installed Qty
- 1
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 94%
Sustainability Information
- ENERGY STAR Certified
- 43.46 cm
- 38.22 cm
- 4.32 cm
- 7.88 kg
- 10 °C
- 35 °C
- 8 - 90% (non-condensing)
- Sound Emission
- 27 dBA
Internal Hard Drives (1)
HPE 1TB 6G SATA 7.2K 2.5IN SFF | In Stock | £222.98 |
Other bundles (4)
HPE HP ProLiant Essentials Integrated Lights-Out Advanced Pack | In Stock | £96.41 |
HPE HP Ethernet 1GB 2P 332T Adaptor | In Stock | £39.09 |
HP iLO Adv incl 3yr TS U E-LTU | In Stock | £149.53 |
HPE Ethernet 1GB 4-Port 366T Adapter | In Stock | £164.89 |
