HPE ProLiant DL180 Gen9 Intel Xeon E5-2603v3 8GB
Quicklinx: 9XXSWS00 Mfr#: 784104-425
  • Xeon
  • Red Hat Enterprise Linux
  • DVD-RW
Do you need a cost-effective server that can keep pace with your data growth while providing options to manage and deliver performance? The HPE ProLiant DL180 Gen9 Server delivers an optimized 2U server, designed with the right balance of expandability, performance, reliability and manageability all in a new compact chassis, making it the ideal platform for SMBs and Enterprises running the "New Style of IT", applications such as Hadoop, Cloud and mobility applications which need right mix of compute and storage.
  • Scalability and Performance To Meet the New Standard of Growing Data Center Needs
    The HPE ProLiant DL180 Gen9 Server provides ample storage capacity on demand with drive configurations ranging from (4) to (12) Large Form Factor (LFF) or (8) to (16) Small Form Factor (SFF) HPE SmartDrives, with flexibility of LFF non-hot plug (NHP) options at the right economics.It supports up to two Intel Xeon processor E5-2600 v3/v4 processors with up to (12) cores and (16) DIMM slots of HPE DDR4 SmartMemory offering improved performance and efficiency.Comes standard with 2x1GbE and choice of HPE FlexibleLOM or PCIe standup 1GbE or 10GbE Adapters provide you flexibility of networking bandwidth and fabric so you can adapt and grow to changing business needs.Up to six PCIe 3.0 riser slots to support a wide range of GPUs and networking cards offering increased IO bandwidth and seamless expandability.Embedded SATA HPE Dynamic Smart Array B140i Controller for boot and data. Choice of HPE Smart Array Controllers with increased performance, data availability with 12 Gb/s SAS technology or HPE Smart HBAs with reliable high performance SAS connectivity capable of running HBA mode or simple RAID mode.
  • High Availability and Efficiency for Dense Storage Applications
    The HPE ProLiant DL180 Gen9 Server supports HPE SmartDrive technology which improves serviceability and prevents data loss with features, such as, self-describing LEDs and a Do Not Remove icon.HPE SmartMemory prevents data loss and downtime with enhanced error handling. Support of up to 512 GB max capacity with speeds up to 2133 MHz with up to 14% performance gain.80 PLUS certified entry-level redundant HPE Power Supplies provide up to 92% efficiency which combined with HPE power management features leads to reduction of power consumption.Improved ambient temperature standard with ASHRAE A3 and A4 helps customers reduce cooling expense.ENERGY STAR qualified server configurations illustrate a continued commitment to helping customers conserve energy and save money.
  • Agile Infrastructure Management for Accelerating IT Service Delivery
    With HPE ProLiant DL180 Gen9 Server, HPE OneView provides infrastructure management for automation simplicity across servers, storage and networking.Online personalized dashboard for converged infrastructure health monitoring and support management with HPE Insight Online.Configure in UEFI boot mode, provision local and remote with Intelligent Provisioning and Scripting Toolkits.Embedded management to deploy, monitor and support your server remotely, out of band with HPE iLO.Optimize firmware and driver updates and reduce downtime with Smart Update, consisting of SUM (Smart Update Manager) and SPP (Service Pack for ProLiant).
HPE ProLiant DL180 Gen9 - rack-mountable - Xeon E5-2603V3 1.6 GHz - 8 GB - no HDD
Server - rack-mountable - administrator password, power-on password, serial port I/O control, UEFI BIOS
Height (Rack Units)
2U
Server Scalability
2-way
1 x Intel Xeon E5-2603V3 / 1.6 GHz (6-core)
Processor Socket
LGA2011-v3 Socket
Cache Memory
15 MB L3 Cache
Cache Per Processor
15 MB
RAM
8 GB (installed) / 256 GB (max) - DDR4 SDRAM - Advanced ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s) (HP Dynamic Smart Array B140i)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
DVD-Writer
Graphics Controller
Matrox G200eH2
GigE
44.55 cm x 60.7 cm x 8.75 cm
16.59 kg
Manufacturer Selling Program
HP Top Value
Limited warranty - parts - 3 years - response time: next business day , Limited warranty - parts and labour - 1 year - on-site - response time: next business day
Server
Recommended Use
Small business, corporate business
Product Form Factor
Rack-mountable - 2U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
2-way
Front Accessible Bays Qty
4
Processor / Chipset
CPU
Clock Speed
1.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
2
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
L3 Cache - 15 MB
Cache Per Processor
15 MB
RAM
Installed Size
8 GB / 256 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, HP SmartMemory
Configuration Features
1 x 8 GB
RAM Supported
PC4-17000 - 256 GB registered - ECC , PC4-17000 - 512 GB Load-Reduced - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - integrated
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
10
RAID Level
RAID 0, RAID 1, RAID 5
Optical Storage
DVD-RW DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200eH2
Video Interfaces
VGA
Integrated
Interface (Bus) Type
PCI Express 2.0 x2
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
HP NC361i
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL), PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 1 (free) x external , 4 (total) / 4 (free) x 3.5" LFF
Slots
2 (total) / 1 (free) x CPU , 16 (total) / 15 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x8 - half-length, full-height , 1 (total) / 1 (free) x microSD Card (internal)
2 x LAN (Gigabit Ethernet) - RJ-45 , 1 x HPE iLO - RJ-45 , 1 x VGA , 1 x USB 2.0 (1 in front) , 3 x USB 3.0 (2 rear, 1 internal)
HP Easy Install Rails
Administrator password, power-on password, serial port I/O control, UEFI BIOS
ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 4943, GB 9254, CNS 14336, CNS 13438
HP Top Value
Power supply
Power Provided
550 Watt
Efficiency
89%
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
44.55 cm
60.7 cm
8.75 cm
16.59 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
39 dBA
9XXS C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
