HP ProLiant DL160 Gen8, a dual-socket 1U rack server, provides high performance computing with increased manageability in affordable design. It is ideal for environments requiring high performance computing as well as for service providers with web serving, hosting, virtualization, and database needs.
Unprecedented HPC and Hyperscale capabilities in an efficient design
HPE SmartMemory improves workload performance and power efficiency while preventing data loss and downtime with enhanced error handling. Support for RDIMMs and UDIMMs with up to 768GB max capacity .HPE FlexibleLOM provides you additional choice of networking bandwidth and fabric so you can adapt to changing business needs.New generation of Smart Array RAID controller and support for HPE Smart Storage including PCIe 3.0, HPE SmartDrives, and HPE Flash Backed Write Cache with capacity up to 2GB. Choice of up to eight 2.5-inch SFF or four 3.5-inch LFF SAS, SATA, SSD drives with optical media. -
Unlock your Infrastructure's Potential with HP's Easy-to-Use Integrated Management and Support
HPE iLO Management Engine is a complete set of embedded features, standard on all ProLiant Gen8 servers. Includes HPE iLO, HPE Agentless Management, HPE Active Health System, HPE Intelligent Provisioning, and HPE Embedded Remote Support.HPE Insight Control provides advanced management capabilities across the lifecycle of your HPE ProLiant server infrastructure. HPE iLO Advanced, a key component, provides enhanced remote server functions that reduce IT travel costs, while increasing Time-To-Resolution.HPE Insight Online with HPE Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE SmartUpdate reduces deployment time and update complexity by systematically updating server infrastructure in the data center. Includes HPE Smart Update Manager (HPE SUM), and Service Pack for ProLiant (SPP), and other products. -
Proactive Service and Support to Redefine Service Experience
HPE Insight Online with HPE Insight Remote Support provides 24X7 remote monitoring and anywhere, anytime personalized access to your IT and support status.HPE proactive support services enable industry leading performance, uptime and productivity integrated into a personalized, simplified support experience.Through HPE ServiceOne partners, you get responsive qualified partners to help you plan, manage and deliver solutions spanning the entire IT lifecycle.User-inspired design features that prevent data loss, reduce downtime, and improve serviceability include HPE SmartDrives, HPE Smart Socket guides, "Snap and Go" rail kit options, and tool-less access to components. -
Energy Efficiency Leadership
Automated Energy Optimization reclaims space, power, and cooling resources needed for workloads and extends your data center capacity.High efficiency 80+ certified HPE Common Slot Power Supplies provide up to 94% efficiency (Platinum) and support HP's Power Discovery Services.Right-sized HPE ProLiant power supplies meet the exact needs, reclaiming lost data center power. Less oversubscription means more capacity opportunity. Be sure to use the HPE Power Adviser for selecting the right size power supply.ENERGY STAR qualified server configurations illustrate HP's continued commitment to helping customers conserve energy and save money.
- HPE ProLiant DL160 Gen8 Performance - rack-mountable - Xeon E5-2640 2.5 GHz - 16 GB - no HDD
- Server - rack-mountable - administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- Height (Rack Units)
- 1U
- Localisation
- Region: Europe
- Server Scalability
- 2-way
- Processor
- 2 x Intel Xeon E5-2640 / 2.5 GHz (3 GHz) (6-core)
- Cache Memory
- 30 MB
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 384 GB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) (Smart Array P420i with 1GB FBWC); SATA (SATA 6Gb/s)
- Server Storage Bays
- Hot-swap 2.5"
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 43.5 cm x 70 cm x 4.3 cm
- 14.1 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Server
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Rack-mountable - 1U
- 2-way
- Front Accessible Bays Qty
- 1
- Hot-Swap Bays Qty
- 8
- Localisation
- Region: Europe
Processor / Chipset
- CPU
- Intel Xeon E5-2640
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 6-core
- 64-bit Computing
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C600
Cache Memory
- Installed Size
- 30 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 384 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 24 (Total) / 20 (empty)
- Registered, quad channel memory architecture, HP SmartMemory
- Configuration Features
- 4 x 4 GB
- RAM Supported
- PC3-12800 - 384 GB registered , PC3-10600 - 128 GB unbuffered
Hard Drive
- No HDD
Storage Controller
- 1 x RAID - plug-in card
- Controller Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Storage Controller Name
- Smart Array P420i with 1GB FBWC
- RAID Level
- RAID 0, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Storage Controller (2nd)
- 1 x SATA - integrated
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Matrox G200
- Video Interfaces
- VGA
Input Device
- Mouse, keyboard
- Integrated
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- HP NC361i
- Data Link Protocol
- Remote Management Controller
- Integrated Lights-Out 4
- Wake on LAN (WoL), PXE support
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP)
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 8 (total) / 8 (free) x hot-swap 2.5" SFF
- Slots
- 24 (total) / 20 (free) x DIMM 240-pin , 2 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x8 - low-profile
- 1 x serial , 2 x VGA (1 front, 1 rear) , 2 x LAN (Gigabit Ethernet) , 1 x HPE iLO , 6 x USB 2.0 (2 front, 4 rear)
- Administrator password, power-on password, keyboard password, serial port I/O control, quick lock
- ACPI 2.0b, FCC Class A certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, BSMI CNS 13438
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
Operating System / Software
- OS Certified
- SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris
- ENERGY STAR Certified
- 43.5 cm
- 70 cm
- 4.3 cm
- 14.1 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
