HPE ProLiant DL160 Gen10 Intel Xeon Bronze 3106 16GB
Quicklinx: F8KQWS00 Mfr#: 878968-B21
Case Style: Rack-mountable
Processor Type: Xeon Bronze
Hard Disk Capacity: 0GB
Processor Speed: 1.7GHz
Installed Memory: 16GB
Hurry, only 3 left in stock!
£1,035.10 ex VAT
£1,242.12 inc VAT
Are you searching for a dense server with exceptional value to run on-premises and hybrid cloud solutions? The secure HPE ProLiant DL160 Gen10 server delivers the right balance of performance, storage, reliability, manageability and efficiency in a dense and compact chassis, to meet the needs of growing businesses of a diverse set of customers - from SMB to service providers running wide range of workloads.
HPE ProLiant DL160 Gen10 Entry - rack-mountable - Xeon Bronze 3106 1.7 GHz - 16 GB
Server - rack-mountable
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon Bronze 3106 / 1.7 GHz (8-core)
Cache Memory
11 MB L3 Cache
Cache Per Processor
11 MB
RAM
16 GB (installed) / 256 GB (max) DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s) - PCIe 3.0 x4 (HPE Smart Array S100i)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
No HDD
Optical Storage
No optical drive
GigE
Power Redundancy
Optional
43.46 cm x 61.49 cm x 4.29 cm
11.65 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site - response time: next business day
Server
Product Form Factor
Rack-mountable - 1U
Server Scalability
2-way
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C622
Cache Memory
Installed Size
L3 Cache - 11 MB
Cache Per Processor
11 MB
RAM
Installed Size
16 GB / 256 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
8 (Total) / 7 (empty)
Registered
Configuration Features
1 x 16 GB
Hard Drive
No HDD
Storage Controller
1 x SATA - PCIe 3.0 x4
Controller Interface Type
SATA 6Gb/s
Storage Controller Name
Channel Qty
14
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
VGA
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Protocol
SNMP 3, IPMI 2.0
Wake on LAN (WoL), PXE support
Bays
4 (total) / 4 (free) x hot-swap 3.5" LFF
Slots
1 (total) / 1 (free) x microSD Card (internal) , 1 (total) / 1 (free) x FlexibleLOM (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, half-height
1 x VGA , 2 x LAN (Gigabit Ethernet) , 1 x HP iLO , 1 x management , 4 x USB 3.0 (1 front, 2 rear, 1 internal)
HPE Easy Install Rails
WEEE, ASHRAE Class A4, ASHRAE Class A3, ACPI 6.1
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
ENERGY STAR Certified
ENERGY STAR Version
2.1
43.46 cm
61.49 cm
4.29 cm
11.65 kg
10 °C
35 °C
8 - 90% (non-condensing)
Sound Emission
28.1 dBA
Brand: HPE
Price Range Ex VAT: 1000 - 1500
