HPE ProLiant BL685c Gen7 AMD Opteron 6380 64GB NO HDD
Quicklinx: 9NP4WS00 Mfr#: 699066-B21
  • Opteron
  • Red Hat Enterprise Linux
The HP ProLiant BL685c G7 Server Blade delivers scale-up, dense, cost-effective 4-socket performance for high-density virtualization and compute-intensive database environments. With up to 64 cores in a single blade and 32 DDR3 registered DIMM slots offering an impressive 1TB memory footprint, these servers are the ideal choice for the most demanding applications. Delivering over 80 Gb of I/O bandwidth with four embedded HP NC551i Dual Port 10Gb FlexFabric Converged Network Adapter ports and three I/O expansion slots, this is the ideal 4-socket blade for enterprise data centers that demand cost-effective performance and scalability.
  • Multicore Scalability-Up to 64 Cores
    Up to four 4-, 8-, 12- or 16-core AMD Opteron processors, delivering outstanding compute power for high-density virtualization and compute-intensive database environments.High core count processors enable scaling of VM density for greater consolidation and increased performance with multiple cores per VM for more robust virtualization configurations.
  • Cost Effective with up to 1 TB of Memory and I/O Bandwidth over 80 Gb
    Economical blade design, for greater flexibility and lower TCO, reduces the amount of hardware required for the same performance.Up to 1 TB of DDR3 Registered DIMMs with Advanced ECC enables a large memory footprint for demanding memory intensive applications.Two embedded HP NC551i Dual Port FlexFabric 10Gb Converged Network Adapters deliver bandwidth for network intensive applications with Up To sixteen (16) connections to network and storage.Lower your infrastructure costs and simplify management by converging LAN and SAN traffic over the same flexible connection.Divide and fine-tune network and storage bandwidth to match application requirements with protocol offload for TCP/IP, FCoE, and iSCSI.
  • Industry-Leading Infrastructure Management for Virtual and Physical Servers
    Deploy servers quickly, proactively manage virtual or physical server health, and reduce power consumption with HP Insight Control.Save time and conserve valuable IT resources by simplifying remote management with HP Integrated Lights-Out 3 (iLO 3).Achieve agility through Cloud Infrastructure Management software with HP Matrix Operating Environment.
HPE ProLiant BL685c G7 - blade - Opteron 6380 2.5 GHz - 64 GB - no HDD
Server - blade - administrator password, power-on password, USB port control
Server Scalability
4-way
4 x AMD Opteron 6380 / 2.5 GHz (3.4 GHz) (16-core)
Cache Memory
64 MB L3 Cache
Cache Per Processor
16 MB
RAM
64 GB (installed) / 512 GB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SAS-2 (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i with 1GB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ATI ES1000
GigE, 10 GigE
5.56 cm x 50.95 cm x 36.63 cm
8.7 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Blade
Server Scalability
4-way
Hot-Swap Bays Qty
2
Processor / Chipset
CPU
AMD Opteron 6380
Clock Speed
2.5 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
16-core
CPU Qty
4
Max CPU Qty
4
CPU Upgradability
Upgradable
Chipset Type
AMD SR5690/SP5100
Cache Memory
Installed Size
L3 Cache - 64 MB
Cache Per Processor
16 MB
RAM
Installed Size
64 GB / 512 GB (max)
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
32 (Total) / 16 (empty)
Registered
Configuration Features
16 x 4 GB
RAM Supported
PC3-12800 - 512 GB registered , PC3-8500 - 1 TB registered , PC3-10600 - 512 GB - low voltage - registered
Hard Drive
No HDD
Storage Controller
1 x SAS-2 - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1
Buffer Size
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Integrated
Interface (Bus) Type
PCI Express 2.0 x8
Ethernet Ports
4 x 10 Gigabit Ethernet
Ethernet Controller
2 x HP NC551i
Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Controller
Wake on LAN (WoL)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ap
Bays
2 (total) / 2 (free) x hot-swap 2.5" SFF
Slots
4 (total) / 0 (free) x CPU , 32 (total) / 16 (free) x DIMM 240-pin , 3 (total) / 3 (free) x expansion slot , 1 (total) / 1 (free) x microSD Card
1 x HPE iLO , 4 x LAN (10Gigabit Ethernet) , 1 x USB (1 internal)
Administrator password, power-on password, USB port control
ACPI 2.0, WEEE
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
5.56 cm
50.95 cm
36.63 cm
8.7 kg
10 °C
35 °C
10 - 90% (non-condensing)
