HPE ProLiant BL680c Gen7 Intel Xeon E7-4860 64GB NO HDD
Quicklinx: 9NP1WS00 Mfr#: 643780-B21
  • Xeon
  • Red Hat Enterprise Linux
The BL680c G7 provides maximum performance and unparalleled scale-up expansion never before seen in a 4P x86 blade. This creates an extremely powerful database engine while handling very demanding workloads and making traditional 4P rack to blade transition a true reality. The ProLiant BL680c G7 supports the E7-4800 family and E7-8867L processors. Four 130W processors are supported with 64 RDIMM slots for 2.0TB of memory, 7 PCIe Gen2 I/O slots, and 6 10Gb FlexFabric CNA ports for standard Ethernet to advanced networking. By designing a balanced architecture, the server is a very unique 4P blade offering ensuring all subsystems are used effectively. Traditional 4P blades are often unbalanced, providing CPU performance and density at the expense of proportional memory and I/O bandwidth. These server often fail when faced with larger databases, higher-density virtualization and general data-intensive applications.
  • Never Before Seen Multiprocessor Scalability in a Blade Server
    World's first 4P server blade to support a two terabytes of memory providing the ultimate database machine, ability to handle very large consolidation projects and a variety of data-demanding workloads.Up to four top performing Intel Xeon E7-4800 processors each up to 130 watts deliver maximum computing power.60 Gb of embedded FlexFabric ports and seven (7) I/O expansion slots bring the total maximum I/O bandwidth to 192 Gb supporting up to 273 VMs.Four hot-plug SAS/SATA/SSD bays for up to 4.0 TB of internal storage powered by a high performance Smart Array P410i 6Gb controller for RAID 0 and 1 standard and optional flash backed write cache options to 1 GB with RAID 1+0, 5, and 6 capability.
  • Six Embedded HP Virtual Connect 10Gb FlexFabric Adapters
    Six embedded NC553i 10Gb Converged Network Adapter ports deliver extensive bandwidth for network intensive applications with up to Up to 24 connections to network and storage without the need for add-in I/O mezzanine cards.Integrated Fibre Channel over Ethernet (FCoE) and hardware-based iSCSI with iSCSI boot simplify management and lower infrastructure costs by converging LAN and SAN traffic over the same flexible connection.Ability to utilize the adapter high-end FlexFabric features or configure than as standard 1Gb or 10Gb Ethernet ports.
  • Making Multiprocessor Server Rack to Blade Transition a True Reality
    Performance, memory, and I/O slot expandability equal to or greater than a typical 4P x86 rack server.Reduce rack space up to 58%. Consolidate four standard 4P rack servers and eight high performance LAN/SAN edge switches (that can occupy up to 24U) into a single 10U c7000 enclosure.Radically simplify system design and lower cost by eliminating all rack server to edge switch cables and decrease power cables to no more than six.The HP BladeSystem enclosures also eliminate individual server management cables, consolidating them into just one (or two for redundancy) even further simplifying system design.
  • Fully Balanced, Optimized Intel Xeon 4S Architecture
    With major advances in processor performance, applications are already memory and I/O bound, not processor. Yet, typical server blades are often unbalanced, providing processor performance and density at the expense of proportional memory capacity, I/O bandwidth, and storage.The Intel Xeon E7-4800 processor family represent Intel's greatest performance leap in history over the previous generation Intel Xeon 4-core 7400 series. Rather than provide a processor-heavy design, the BL680c G7 fully optimizes all the capabilities of the E7-4800 multiprocessor 4S architecture.Each socket includes the maximum allowable two memory controllers that each have two Intel Scalable Memory Interface (SMI) buses. Each SMI connects to a memory buffer that supports four 16 GB DIMMs for a total of 16 DIMMs per processor socket (64 DIMMs or up to 2.0 TB of memory per server).Each socket supports 130 watts allowing up to four maximum performing E7-4800 processors.
HPE ProLiant BL680c G7 - blade - Xeon E7-4860 2.26 GHz - 64 GB - no HDD
Server - blade - administrator password, power-on password, keyboard password, USB port control
Server Scalability
4-way
2 x Intel Xeon E7-4860 / 2.26 GHz (2.67 GHz) (10-core)
Processor Main Features
Intel QuickPath Interconnect
Cache Memory
48 MB L3 Cache
Cache Per Processor
24 MB
RAM
64 GB (installed) / 2 TB (max) - DDR3 SDRAM - PC3-10600
Storage Controller
SAS-2 (SATA 3Gb/s / SAS 6Gb/s) - PCIe 2.0 x4 (Smart Array P410i)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ATI ES1000
GigE, 10 GigE
10.72 cm x 51.03 cm x 36.73 cm
15.93 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Blade
Server Scalability
4-way
Hot-Swap Bays Qty
4
Processor / Chipset
CPU
Intel Xeon E7-4860
Clock Speed
2.26 GHz
Max Turbo Speed
2.67 GHz
Number of Cores
10-core
64-bit Computing
CPU Qty
2
Max CPU Qty
4
CPU Upgradability
Upgradable
Chipset Type
Intel 7500
Cache Memory
Installed Size
L3 Cache - 48 MB
Cache Per Processor
24 MB
RAM
Installed Size
64 GB / 2 TB (max)
DDR3 SDRAM
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
64 (Total) / 56 (empty)
Registered
Configuration Features
8 x 8 GB
Hard Drive
No HDD
Storage Controller
1 x SAS-2 - integrated - PCIe 2.0 x4
Controller Interface Type
Storage Controller Name
Smart Array P410i
RAID Level
RAID 0, RAID 1, RAID 10
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ATI ES1000
Integrated
Interface (Bus) Type
PCI Express 2.0 x8
Ethernet Ports
6 x 10 Gigabit Ethernet
Ethernet Controller
HP NC553i
Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Protocol
SNMP, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 3
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ap
Bays
4 (total) / 4 (free) x hot-swap 2.5" SFF
Slots
4 (total) / 2 (free) x CPU , 64 (total) / 56 (free) x DIMM 240-pin , 7 (total) / 7 (free) x expansion slot , 1 (total) / 1 (free) x microSDHC Card (internal)
1 x HPE iLO , 6 x LAN (10Gigabit Ethernet) , 1 x VGA display / video , 1 x USB 2.0 (1 internal)
Administrator password, power-on password, keyboard password, USB port control
ACPI 2.0
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Oracle Solaris, Citrix XenServer
10.72 cm
51.03 cm
36.73 cm
15.93 kg
10 °C
35 °C
10 - 85% (non-condensing)
