HPE ProLiant BL660c Gen8 Intel Xeon E5-4650 128GB NO HDD
Quicklinx: 9NNQWS00 Mfr#: 679114-B21
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant BL660c Gen8 Server series is ideal for virtualization, database, business processing, and general 4P data-intensive applications where fine-tuning of data center space and price/performance is paramount. Supporting the high-density and cost effective Intel Xeon E5-4600v2 processors, the BL660c Gen8 Server series redefines density-optimized 4-socket blade technology without compromising on performance, scalability, and expandability. Hardware enhancements include the HP SmartDrives, Smart Socket guide, SmartMemory, FlexibleLOM technology, "3D Sea of Sensors", the embedded Smart Array P220i RAID controller, and more. Software enhancements include HP Integrated Lifecycle Automation, Dynamic Workload Acceleration, Automated Energy Optimization, Intelligent Provisioning, agentless hardware monitoring, and Active Health System to name just a few.
  • Ideal 4-socket Dense Form Factor without Compromising on Performance, Scalability, and Expandability
    The HP ProLiant BL660c Gen8 Server series delivers 4S computing in a single-wide, full-height form factor. It has support for up to four cost-effective Intel Xeon E5-4600v2 processors each with up to 12 cores and 130 watts without system configuration restrictions.The BL660s Gen8 provides 32 DDR3 DIMM sockets for up to 1.0TB of Gen8 HP SmartMemory.Each BL660c Gen8 has three PCIe 3.0 expansion slots (two x16) supporting the highest performing mezzanine option cards now and into the future.The Gen8 FlexibleLOM solution for choice of embedded networking supports up to four 10Gb FlexFabric ports.
  • Redefining the Customer Experience with Innovative Design Features
    The HP ProLiant BL660c Gen8 Server series has user-inspired design features such as HP SmartDrives and the HP Smart Socket guide that anticipate your needs and reduces common issues that result in downtime.It delivers Integrated Lifecycle Automation, an industry first, providing embedded provisioning tools, Active Health monitoring, and system maintenance capabilities standard on all ProLiant servers and built using the industry-leading HP iLO Management Engine.Dynamic Workload Acceleration delivers smarter data protection for ever-increasing hard drive capacities and is built-in each BL660c Gen8 Server series.The BL660c Gen8 provides Automated Energy Optimization improving the server's ability to analyze and respond to the "3D Sea of Sensors" within the server, and self-identify its location and inventory through Insight Control for increased workload improvement across the data center.
  • Improved Memory, Storage, and I/O Performance
    HP Gen8 SmartMemory provides unmatched performance, quality, manageability, and efficiency advantages above industry standards including less power using low voltage RDIMMS with no impact to performance.The BL660c Gen8 comes with the Gen8 embedded Smart Array P220i RAID controller with optional 512MB Flash Backed Write Cache (FBWC). It has support for HP Smart Storage and HP SmartDrives and a choice of a very wide section of two 2.5-inch small form-factor (SFF) SAS, SATA and SSD drives.It provides PCIe 3.0 I/O technology with one x8 and two x16 slots to support reduced latency and additional bandwidth per I/O expansion slot as compared to G7 blade servers.HP FlexibleLOM provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware. It provides a choice of networking bandwidth, technology, HP OEM vendor partner, and number of ports.
  • Intuitive, Configurable Management System Reduces Tedious, Time-consuming Tasks
    The HP ProLiant BL660c Gen8 Server series delivers HP Intelligent Provisioning taking strengths from products like HP SmartStart, HP Smart Update Manager and HP Service Pack for ProLiant, enhances them with the latest ease-of-use features and places them on the system board.Agentless hardware monitoring and alerting capabilities are built into the server with HP Agentless Management (runs on the iLO 4 chipset). Starts working the moment that a power cord and an Ethernet cable is connected to the enclosure.HP Active Health System provides 24x7 continuous health monitoring, 100% configuration change logging and faster problem analysis with HP Service and Support. Start problem analysis quicker using unified diagnostic tools with secure data transfer to HP Service and Support.
HPE ProLiant BL660c Gen8 Performance - blade - Xeon E5-4650 2.7 GHz - 128 GB - no HDD
Server - blade - administrator password, power-on password, keyboard password, serial port I/O control
Server Scalability
4-way
4 x Intel Xeon E5-4650 / 2.7 GHz (3.3 GHz) (8-core)
Cache Memory
80 MB L3 Cache
Cache Per Processor
20 MB
RAM
128 GB (installed) / 512 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SAS-2 (SAS 6Gb/s) - PCIe x4 (Smart Array P220i with 512MB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE, 10 GigE
5.654 cm x 51.667 cm x 36.627 cm
9.2 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Blade
Server Scalability
4-way
Hot-Swap Bays Qty
2
Processor / Chipset
CPU
Intel Xeon E5-4650
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
8-core
64-bit Computing
CPU Qty
4
Max CPU Qty
4
CPU Upgradability
Upgradable
Cache Memory
Installed Size
L3 Cache - 80 MB
Cache Per Processor
20 MB
RAM
Installed Size
128 GB / 512 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
32 (Total) / 16 (empty)
Registered, quad channel memory architecture, HP SmartMemory
Configuration Features
16 x 8 GB
RAM Supported
PC3-12800 - 512 GB registered , PC3-10600 - 1 TB Load-Reduced
Hard Drive
No HDD
Storage Controller
1 x SAS-2 - PCIe x4
Controller Interface Type
SAS 6Gb/s
Storage Controller Name
RAID Level
RAID 0, RAID 1
Buffer Size
512 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Plug-in card
Interface (Bus) Type
FlexibleLOM
Ethernet Ports
4 x 10 Gigabit Ethernet
Ethernet Controller
2 x HP 554FLB
Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Protocol
SNMP, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ap, IEEE 802.1Qau
Bays
2 (total) / 2 (free) x hot-swap 2.5" SFF
Slots
4 (total) / 0 (free) x CPU , 32 (total) / 16 (free) x DIMM 240-pin , 3 (total) / 3 (free) x expansion slot , 2 (total) / 0 (free) x FlexibleLOM , 1 (total) / 1 (free) x microSDHC Card (internal)
1 x HPE iLO , 4 x LAN (10Gigabit Ethernet) , 1 x USB 2.0 (1 internal)
Administrator password, power-on password, keyboard password, serial port I/O control
ACPI 2.0
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux, Citrix XenServer
5.654 cm
51.667 cm
36.627 cm
9.2 kg
10 °C
35 °C
10 - 90% (non-condensing)
9NNQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
