HPE ProLiant BL460c Gen8 E5-2650L 1.80GHz 8-core Server
Quicklinx: 80P2WS00 Mfr#: 666163-B21
  • Xeon
  • Red Hat Enterprise Linux
The HP ProLiant BL460c Gen8 Server Blade is a dual-socket server blade engineered for unprecedented performance, enhanced flexibility and simplified management which makes it the standard for data center computing. It packs in more performance with a 33% increase in memory DIMM count, Intel Xeon E5-2600 v2 Processors, faster I/O slots and enhanced Smart Array Controller that now ships with 512MB Flash Back Write Cache standard. In addition, it is also more flexible with the HP FlexibleLOM which provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware.
  • Redefining the Customer Experience
    User-inspired design features like HPE SmartDrive carriers and the HPE Smart Socket guide anticipate your needs and virtually eliminate common issues that result in downtime.Integrated Lifecycle Automation, an industry first, provides embedded provisioning tools, Active Health monitoring, and system maintenance capabilities standard on all ProLiant servers using the industry-leading HPE iLO Management Engine.Dynamic Workload Acceleration delivers smarter data protection for ever-increasing drive capacities, real-time workload-aware analysis to optimize and adapt storage performance, and 6X faster solid state performance versus previous generation.Automated Energy Optimization improves the server's ability to analyze and respond to "3D sea of sensors" data within the server as well as self-identify location and inventory through Insight Control for maximum workload optimization across the entire datacenter.
  • Intuitive, Configurable Management System Eliminates Tedious, Time-Consuming Tasks
    HPE Intelligent Provisioning takes strengths from products like HPE SmartStart, HPE Smart Update Manager and HPE Service Pack for ProLiant, enhances them with the latest ease of use features, and places them where you can use them instantly - on the system board.Agentless hardware monitoring and alerting capabilities are built into the server with HPE Agentless Management (runs on the iLO 4 chipset). Starts working the moment that a power cord and an Ethernet cable is connected to the enclosure.HPE Active Health System provides 24x7 continuous health monitoring, 100% configuration change logging, and faster problem analysis with HPE Service and Support. Start problem analysis 5x faster using unified diagnostic tools with secure data transfer to HPE Service and Support.
  • Improved Application, Storage, and I/O Performance
    HPE SmartMemory has unmatched performance, quality and manageability advantages above industry standard memory. Supports RDIMM, UDIMM and LRDIMM with up to 512GB capacity and 256GB capacity at 1866MHz. SmartMemory in the BL460c Gen8 delivers up to 33% more memory capacity over previous generations.Embedded Smart Array P230i (HPE Secure Encryption capable) or P220i RAID controller with 512MB Flash Backed Write Cache standard. Support for HPE Smart Storage and HPE SmartDrives. Choice of two (2) 2.5-inch SFF SAS, SATA, SSD drives.PCIe 3.0 technology provides improved latency and up to 400% the bandwidth per I/O expansion slot compared to ProLiant BL460c G7.Two x16 PCIe 3.0 I/O expansion slots support the highest performing mezzanine option cards now and into the future.HPE FlexibleLOM provides the ability to customize server networking today and the ability to meet future needs without overhauling server hardware. Provides choice of bandwidth and fabric (Ethernet, FCoE, InfiniBand), supports WOL, and provides a shared iLO port for ease of use.
  • Built for Performance and Easier Access
    Improved access to mezzanine cards enables quicker removal and easy access to the new FlexibleLOM card. The DIMM tool included inside every ProLiant BL460c Gen8 makes the removal and insertion of individual DIMMs even easier.Intel Xeon E5-2600 v2 Processor Family offers higher performance, power efficiency, more adaptability, and enhanced security with Intel QuickPath, Integrated Memory Controller, Turbo Boost ,Intelligent Power Technologies, Intel Secure Key, Intel OS Guard, and Floating Point Bit Depth Conversion.Expanded memory options now include the HPE 24GB (1x24GB) Three Rank x4 PC3L-10600R (DDR3-1333) Registered Low Voltage FIO Memory Kit.
HPE ProLiant BL460c Gen8 - blade - Xeon E5-2650L 1.8 GHz - 32 GB - no HDD
Server - blade - administrator password, system password, power-on password, serial port I/O control
Server Scalability
2-way
1 x Intel Xeon E5-2650L / 1.8 GHz (2.3 GHz) (8-core)
Cache Memory
20 MB L3 Cache
Cache Per Processor
20 MB
RAM
32 GB (installed) / 512 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SAS-2 (SATA 3Gb/s / SAS 6Gb/s) - PCIe x4 (Smart Array P220i with 512MB FBWC)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Matrox G200
GigE, 10 GigE
5.5 cm x 51.8 cm x 18.1 cm
6.3 kg
Limited warranty - parts and labour - 3 years - on-site
Server
Recommended Use
Small business, corporate business
Product Form Factor
Blade
Server Scalability
2-way
Hot-Swap Bays Qty
2
Processor / Chipset
CPU
Intel Xeon E5-2650L
Clock Speed
1.8 GHz
Max Turbo Speed
2.3 GHz
Number of Cores
8-core
64-bit Computing
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Chipset Type
Intel C600
Cache Memory
Installed Size
L3 Cache - 20 MB
Cache Per Processor
20 MB
RAM
Installed Size
32 GB / 512 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
16 (Total) / 12 (empty)
Registered, quad channel memory architecture, HP SmartMemory
Configuration Features
4 x 8 GB
RAM Supported
PC3-12800 - 512 GB registered , PC3-10600 - 128 GB unbuffered - Advanced ECC
Hard Drive
No HDD
Storage Controller
1 x SAS-2 - integrated - PCIe x4
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1
Buffer Size
512 MB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Matrox G200
Integrated
Interface (Bus) Type
PCI Express 2.0 x8
Ethernet Ports
2 x 10 Gigabit Ethernet
Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Protocol
SNMP, IPMI 2.0, SMASH CLP
Remote Management Controller
Integrated Lights-Out 4
Wake on LAN (WoL)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ap
Bays
2 (total) / 2 (free) x hot-swap 2.5" SFF
Slots
2 (total) / 1 (free) x CPU , 16 (total) / 12 (free) x DIMM 240-pin , 2 expansion slot , 1 (total) / 1 (free) x SD card
1 x HPE iLO , 2 x LAN (10Gigabit Ethernet)
Administrator password, system password, power-on password, serial port I/O control
ACPI 2.0b, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, IEC 60950-1, EN 60950-1, BSMI CNS 13438, FCC CFR47 Part 15 B
Operating System / Software
OS Certified
SUSE Linux Enterprise Server, Red Hat Enterprise Linux, Microsoft Windows Server 2008, Oracle Solaris
5.5 cm
51.8 cm
18.1 cm
6.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
