The Switch 5400zl Series consists of the most advanced intelligent edge switches. The foundation for this switch is a purpose-built, programmable ProVision ASIC that allows the most demanding networking features, such as QoS and security, to be implemented in a scalable yet granular fashion. With a variety of Gigabit interfaces, integrated PoE on all 10/100/1000Base-T ports, and a choice of form factors, the 5400zl switch offers excellent investment protection, flexibility, and scalability, as well as ease of deployment, operation, and maintenance.
- HPE 20p 10/100/1000 + 4p Mini-GBIC Module - expansion module - Gigabit Ethernet x 20
- Expansion module
- Form Factor
- Plug-in module
- Ports
- 20.7 cm x 26.2 cm x 4.5 cm
- 1 kg
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Auxiliary Ports
- 4 x SFP (mini-GBIC)
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Designed For
- HP Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge; HPE 3500-24G-PoE yl Switch, Switch 5406zl Intelligent Edge; HPE Aruba 5406 zl
- Expansion module
- Form Factor
- Plug-in module
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Auxiliary Ports
- 1 Gbps
- Power over Ethernet (PoE), auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode
- Expansion Slots
- 4 (total) / 4 (free) x SFP
- 20 x 1000Base-T (PoE) - RJ-45
- Compatible Slots
- 1 x Expansion Slot
- 20.7 cm
- 26.2 cm
- 4.5 cm
- 1 kg
- 0 °C
- 40 °C
- Designed For
- HP Switch 5406zl-48G Intelligent Edge, Switch 5412zl Intelligent Edge, Switch 5412zl-96G Intelligent Edge , HPE 3500-24G-PoE yl Switch, Switch 5406zl Intelligent Edge , HPE Aruba 5406 zl
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
