The HP 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments. This flexible modular switch supports 10/100, Gigabit Ethernet and 10GbE connectivity and basic IP routing with up to 16 static routes. An optional redundant power supply can be added for uninterrupted power. The HP 4200 vl Switch Series can be seamlessly managed with the optional HP Intelligent Management Center (IMC) Software Platform.
Layer 2 Modular Access Switches
The HP 4200 vl Switch Series provides cost-effective Layer 2 modular switching for enterprise edge deployments.Basic IP routing enables automatic routing to the connected VLANs and up to 16 static routes, including one default route, in IP networks.Optional redundant power supply for uninterrupted power.10GbE modules for bandwidth demanding applications. -
Security with Quality of Service
The HP 4200 vl Switch Series includes security and quality of services features such as traffic prioritization (IEEE 802.1p) which allows real-time traffic classification into eight priority levels mapped to eight queues.Flexible authentication options include 802.1X, MAC and Web Authentication modes for improved security and policy-driven application authentication. -
Single View of the Network
The HP 4200 vl Switch Series can be seamlessly managed with the optional HP Intelligent Management Center (IMC) Software Platform to provide end-to-end network transparency with consistent network experience through comprehensive configuration, compliance and policy management.RMON and sFlow provide advanced monitoring and reporting capabilities for statistics, history, alarms and events.
- HPE 4204 vl Chassis - switch - Managed - rack-mountable
- Switch - Managed
- Enclosure Type
- Rack-mountable 3U
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
- Routing, VLAN support, manageable
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 44.2 cm x 38.9 cm x 13.3 cm
- 10.8 kg
- Limited lifetime warranty
- Switch - Managed
- Enclosure Type
- Rack-mountable 3U
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Processor
- 1 x Motorola MPC8245: 330 MHz
- RAM
- 64 MB SDRAM
- Flash Memory
- 24 MB Flash
- 1 x serial (RS-232) DB-9 management
- Expansion Slots
- 4 (total) / 4 (free) x Expansion Slot
- Installed Modules Qty (Max)
- 0 (installed) / 4 (max)
- Power Device
- Internal power supply
- Power Redundancy
- Voltage Required
- 630 Watt
- Rack Mounting Kit
- Included
- FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, EN55024, CSA 22.2 No. 950, UL 60950
- 44.2 cm
- 38.9 cm
- 13.3 cm
- 10.8 kg
- Limited warranty - advance parts replacement - lifetime - response time: next business day
- 0 °C
- 40 °C
- 15 - 95%
