HPE OfficeConnect 1920S 24G 2SFP PPoE+ 185W  Switch  L3
Quicklinx: D01CWS00 Mfr#: JL384A
Type: Gigabit Ethernet
Ports: 24
Managed: Yes
POE: PoE+
£510.98 ex VAT
£613.17 inc VAT
The HPE OfficeConnect 1920S switch is designed for small businesses that require enhanced performance to support bandwidth-demanding applications. It is ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. This is a sophisticated smart-managed fixed configuration Gigabit switch optimized for small business price/performance.
  • Simplifies Network Deployment and Management for Small Organizations
    The HPE OfficeConnect 1920S Switch Series features easy-to-use, out of the box, plug-and-play deployment.The series offers a complete portfolio of choices for increased small business flexibility. It consists of six rack-mountable models including 8G-, 24G- and 48G-port with and without PoE+. The 24G- and 48G-port PoE+ models offer SPF fiber connectivity.These smart-managed switches use an intuitive Web management interface, to simplify deployment and management while offering granular control of key features.
  • Keeps Your Business Protected with Enhanced Security
    The HPE OfficeConnect 1920S Switch Series supports Energy Efficient Ethernet for lower power consumption and an enhanced feature set for more robust operation.Enhanced security features such as Access Control List, IEEE 802.1x and VLANs guard your network from unwanted or unauthorized access.Management security restricts access to critical configuration commands, offers multiple privilege levels with password protection and supports secure http (https).
  • Delivers Better Performance at a Lower Total Cost of Ownership
    The HPE OfficeConnect 1920S Switch Series delivers advanced functionality in smart-managed switches, including Layer 3 static routes, SFP ports, rate limiting, link aggregation and IGMP.The switch series includes PoE+ options to power IP devices without the cost of additional cabling.Green features like port shutdown and Energy Efficient Ethernet compliance for greater energy-efficiency.The switch series is covered by the Limited Lifetime Warranty with 24x7 phone support for 90 days and business hours thereafter.
HPE OfficeConnect 1920S 24G 2SFP PPoE+ 185W - switch - 24 ports - smart - rack-mountable
Switch - 24 ports - L3 - smart
Enclosure Type
Side to side airflow rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
12 x 10/100/1000 (PoE+) + 12 x 10/100/1000 + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
185 W
Performance
Throughput: 38.6 Mpps , Switching capacity: 52 Gbps , Latency (100 Mbps): 7 µs , Latency (1000Base-T): 2 µs
IPv4 routing table entries: 32
MAC Address Table Size
8000 entries
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, SNMP, RMON, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Flow control, full duplex capability, Layer 2 switching, auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, half duplex mode, full duplex mode, SNTP support, Quality of Service (QoS), DHCP server, fanless, LLDP support, Link Aggregation Control Protocol (LACP), 2MB packet buffer, DiffServ Code Point (DSCP) support, Protocol-based VLANs support, 3MB packet buffer, power-saving mode, Network Timing Protocol (NTP)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3at, IEEE 802.3az
AC 120 V (60 Hz)
44.25 cm x 24.61 cm x 4.39 cm
3.31 kg
Enclosure Type
Side to side airflow desktop, rack-mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
185 W
Performance
8000 entries
Jumbo Frame Support
9216 bytes
Encryption Algorithm
SSL
1 x ARM Cortex-A9: 400 MHz
RAM
256 MB SDRAM
Flash Memory
64 MB
12 x 1000Base-T RJ-45 PoE+ - 185 W , 12 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
AC 120 V (60 Hz)
207.9 Watt
MTBF
64.52 years
CISPR 24, EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, EN 60825-1, VCCI Class A, CNS 13438, ICES-003 issue 5 Class A, FCC CFR47 Part 15 B Class A, EN 55032:2015, CAN/CSA-C22.2 No. 60950-1
44.25 cm
24.61 cm
4.39 cm
3.31 kg
Limited warranty - advance parts replacement - lifetime - shipment - response time: next business day , Technical support - phone consulting - lifetime - shipment
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 24
Managed: Yes
POE: PoE+
Brand: HPE
Price Range Ex VAT: £500 - £750
