The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
Ease of Use
The HPE OfficeConnect 1410 Switch Series offers unmanaged plug-and-play simplicity.Comprehensive LED display with per-port indicators provides an at-a-glance view of status, activity, speed, and full-duplex operation.Auto-speed negotiation automatically selects individual port speed depending on client capabilities without the need for manual intervention.Flow control helps provide reliable communications during full-duplex operation. -
Connectivity and Performance
The HPE OfficeConnect 1410 Switch series provides automatic cable type detection for MDI/MDIX.These switches support Jumbo or Mini-Jumbo packets (based on model) for performance improvement of large data transfers.They double the throughput of every port with Half/Full duplex auto-negotiating capabilities. -
The HPE OfficeConnect 1410 Switch Series allows real-time traffic prioritization by supporting Differentiated Services Code Point (DSCP).IEEE 802.1p prioritization delivers data to devices based on the priority and type of traffic.They support energy-efficient Ethernet and allows lower power consumption when operated with IEEE-compliant client devices.
- HPE OfficeConnect 1410 8G - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- MAC Address Table Size
- 8K entries
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), QoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Power
- AC 120/230 V (50/60 Hz)
- 15.6 cm x 9.7 cm x 2.5 cm
- 340 g
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Gigabit Ethernet
- Ports
- 8 x 10/100/1000
- 8K entries
- Status Indicators
- Port transmission speed, port duplex mode, status, link/activity
- 8 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- 24 Watt
- FCC Class A certified, VCCI, EN 60950, EN55022, ICES-003, IEC 60950, UL 60950, CSA 22.2 No. 60950, FCC Part 15 B
- 15.6 cm
- 9.7 cm
- 2.5 cm
- 340 g
- 0 °C
- 40 °C
- 15 - 95%
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
