Your basket is empty
HPE OfficeConnect 1410 8G - switch - 8 ports - unmanaged
Quicklinx: 71NXWS00 Mfr#: J9559A
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
15.6 cm x 9.7 cm x 2.5 cm
340 g
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
8K entries
Status Indicators
Port transmission speed, port duplex mode, status, link/activity
8 x 1000Base-T RJ-45
External power adapter
24 Watt
FCC Class A certified, VCCI, EN 60950, EN55022, ICES-003, IEC 60950, UL 60950, CSA 22.2 No. 60950, FCC Part 15 B
15.6 cm
9.7 cm
2.5 cm
340 g
15 - 95%
71NX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
71NX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
71NX C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
71NX C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
