Your basket is empty
HPE OfficeConnect 1405-5 Switch V2
Quicklinx: 8JVKWS00 Mfr#: J9791A
Type: Fast Ethernet
Ports: 5
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£15.18 ex VAT
£18.21 inc VAT
The HPE 1405 Switch Series is a plug-and-play unmanaged fixed-port Layer 2 switch designed for small offices. These switches are preconfigured with connections using low-cost Ethernet copper cabling. They are Class B certified, energy efficient and quiet. They support administration-friendly features such as auto-negotiation. Designed for high reliability, long life, and low power consumption, they are ideal for businesses concerned with total cost of ownership.
HPE 1405-5 v2 Switch - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
Throughput: up to 0.7 Mpps
MAC Address Table Size
2K entries
Jumbo Frame Support
9216 bytes
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Jumbo Frames support, fanless, Mini Jumbo Frame support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
11.43 cm x 9.14 cm x 3.56 cm
180 g
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100
Performance
2K entries
Jumbo Frame Support
9216 bytes
RAM
384 KB
Status Indicators
Port status, link activity, port transmission speed
5 x 100Base-TX - RJ-45
External power adapter
CISPR 22 Class B, UL 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15, IEC 60950-1, EN 60950-1, CAN/CSA-C22.2 No. 60065-03
11.43 cm
9.14 cm
3.56 cm
180 g
Limited warranty - advance parts replacement - 3 years , Technical support - phone consulting - 3 years
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
8JVK C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.13
8JVK C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.21
8JVK C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.18
8JVK C2G 2m Cat6a Shielded Patch - Blue In Stock £7.27
8JVK C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £46.27
Type: Fast Ethernet
Ports: 5
Managed: No
POE: No
Brand: HPE
Price Range Ex VAT: 0 - 50
