HPE Converter Enterprise Hard drive with 600 GB hot-swap. A 3.5" for HPE P2000 G3; Modular Smart Array 1040, 2040, P2000 G3
- HPE Converter Enterprise - hard drive - 600 GB - SAS 12Gb/s
- Hard drive - hot-swap
- Capacity
- 600 GB
- Form Factor
- 3.5" LFF
- Interface
- SAS 12Gb/s
- Data Transfer Rate
- 1.2 GBps
- Spindle Speed
- 15000 rpm
- 105.8 mm x 170 mm x 26.8 mm
- Designed For
- HPE P2000 G3; Modular Smart Array 1040, 2040, P2000 G3; StorageWorks Modular Smart Array P2000 G3
- Capacity
- 600 GB
- Form Factor
- 3.5" LFF
- Interface
- SAS 12Gb/s
- Bytes per Sector
- 512
- 105.8 mm
- 170 mm
- 26.8 mm
Performance
- Drive Transfer Rate
- 1.2 GBps (external)
- Seek Time
- 2.9 ms (average) / 5.9 ms (max)
- Track-to-Track Seek Time
- 0.15 ms
- Spindle Speed
- 15000 rpm
Expansion & Connectivity
- 1 x SAS 12 Gb/s
- Compatible Bay
- 3.5" LFF
- Limited warranty - 3 years
- 10 °C
- 35 °C
- Designed For
- HPE P2000 G3 (3.5", 3.5" LFF), P2000 G3 FC Dual Controller (3.5", 3.5" LFF), P2000 G3 FC/iSCSI Dual Controller (3.5", 3.5" LFF), P2000 G3 iSCSI Dual Controller (3.5", 3.5" LFF) , HPE Modular Smart Array 1040 Dual Controller LFF Storage (3.5", 3.5" LFF), 2040 SAN Dual Controller LFF Storage (3.5", 3.5" LFF), 2040 SAS Dual Controller LFF Storage (3.5", 3.5" LFF), P2000 G3 10GbE iSCSI Dual Controller LFF Array System (3.5", 3.5" LFF), P2000 G3 10GbE iSCSI Dual Controller SFF Array System (3.5", 3.5" LFF), P2000 G3 FC Dual Controller LFF Modular Smart Array System (3.5", 3.5" LFF), P2000 G3 FC MSA Dual Controller Virtualization SAN Starter Kit (3.5", 3.5" LFF), P2000 G3 FC/iSCSI Dual Combo Controller LFF Array System (3.5", 3.5" LFF), P2000 G3 iSCSI Dual Controller LFF Array System (3.5", 3.5" LFF), P2000 G3 SAS Dual Controller LFF Array System (3.5", 3.5" LFF), P2000 G3 SAS MSA Dual Controller LFF Array System (3.5", 3.5" LFF) , HPE StorageWorks Modular Smart Array P2000 G3 10GbE iSCSI MSA Dual Controller LFF Array (3.5", 3.5" LFF), P2000 G3 FC Dual Controller (3.5", 3.5" LFF), P2000 G3 FC Dual Controller LFF Array (3.5", 3.5" LFF), P2000 G3 FC Dual Controller Small Business SAN Starter Kit (3.5", 3.5" LFF), P2000 G3 FC/iSCSI Dual Combo Controller LFF Array (3.5", 3.5" LFF), P2000 G3 FC/iSCSI Dual Controller (3.5", 3.5" LFF), P2000 G3 iSCSI Dual Controller (3.5", 3.5" LFF), P2000 G3 iSCSI MSA Dual Controller LFF Array (3.5", 3.5" LFF), P2000 G3 SAS Dual Controller (3.5", 3.5" LFF), P2000 G3 SAS Dual Controller LFF Array (3.5", 3.5" LFF)
