HPE MSA 4TB 12G SAS 7.2K 3.5in MDL HDD
Quicklinx: F7PWWS00 Mfr#: K2Q82A
Form Factor: 3.5" LFF
Type: Hard drive
Capacity: 4TB
Spin Speed (rpm): 7200rpm
£221.79 ex VAT
£266.14 inc VAT
HPE Server Midline hard drives deliver the highest capacity, performance and reliability to your datacenter applications. Midline hard drives allow you to store more data without sacrificing performance or reliability; they are ideal to store all your bulk storage requirements.
All HPE hard drives pass a rigorous qualification process, which certify that every drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE Server Midline hard drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
  • Smart carriers
    HPE Hard Drives with smart carriers are designed to provide an interface to communicate critical status and management information. System status LED icons and a spinning activity ring reflecting the data-writing process notify users of the current system status. A blue LED located behind the handle can be activated remotely to guide users to a specific drive tray, while a do-not-remove icon positioned on the tray's eject button lights up to warn users when the removal of the drive would cause data loss.
  • Helium drives
    Although hard drives are sealed, they have air inside. Air can create turbulence-induced risk vibrations which can limit the storage density of HDDs. Newer helium-filled drives virtually eliminate turbulence because helium is 1/7th as dense as air. This lower density allows the read/write mechanism to spin more easily and precisely, with less drag. Less internal turbulence means the drive platters can be closer together, allowing more platters and increasing the capacity potential in the same space. Less turbulence also means helium drives tend to use less power, and run cooler and quieter.
HPE Midline - hard drive - 4 TB - SAS 12Gb/s
Hard drive - hot-swap
4 TB
3.5" LFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
7200 rpm
1-year warranty
Modular Smart Array 1040 Dual Controller LFF Storage, 2040 LFF Chassis, 2040 LFF DC-power Chassis, 2040 LFF Disk Enclosure, 2040 SAN Dual Controller LFF Storage, 2040 SAS Dual Controller LFF Storage
4 TB
3.5" LFF
SAS 12Gb/s
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
HPE Modular Smart Array 1040 Dual Controller LFF Storage, 2040 LFF Chassis, 2040 LFF DC-power Chassis, 2040 LFF Disk Enclosure, 2040 SAN Dual Controller LFF Storage, 2040 SAS Dual Controller LFF Storage
Type: Hard drive
Capacity: 4TB
Brand: HPE
Price Range Ex VAT: 150 - 300
