HPE MSA 2052 SAS DC LFF Storage
Quicklinx: F8MFWS00 Mfr#: Q1J30A
Type: Solid state / hard drive array
Controller Type: RAID
£8,910.47 ex VAT
£10,692.56 inc VAT
Looking for seriously simple and affordable flash storage? The HPE MSA 2052 SAN Storage is a hybrid flash system designed for affordable application acceleration for small and remote office deployments. Don't let the low cost fool you it gives you the combination of simplicity, flexibility and advanced features you many not expect in an entry-priced array. Start with 1.6 TB of flash capacity included and scale as needed with any combination of solid state disks (SSD), high-performance enterprise, or lower-cost midline SAS-based drives. The HPE MSA 2052 SAN Storage has been the industry-leading entry storage Fibre Channel (FC) platform for the past eight years, with nearly 500,000 systems sold worldwide . Delivering performance in excess of 200,000 IOPS, it can save you up to 40% with an all-inclusive software suite and 1.6 TB of flash capacity included. It's seriously simple and affordable flash storage to help you get high performance for a low cost.
  • Affordable Application Acceleration
    The HPE MSA 2052 SAN Storage performs in excess of 200,000 IOPS delivering outstanding application acceleration for small to medium-sized businesses either locally or remotely.Delivers 2x more performance than the previous HPE MSA 2042 SAN Storage generation .Save 40% on HPE MSA 2052 with all-inclusive software and 1.6 TB of Solid State Drive (SSD) capacity included.
  • Advanced Data Services With No Experience Required
    The HPE MSA 2052 SAN Storage is easy to install, easy to use, easy to maintain, no storage previous expertise required.Automated tiering dynamically responds to workload changes, so you don't have to.
  • Keep Your Business Running with Expanded Data Protection Features
    The HPE MSA 2052 SAN Storage provides updated virtualized snapshot technology making data protection and instant recovery a snap.Remote replication with Fibre Channel (FC) and iSCSI supports an affordable disaster recovery solution.
  • Grow Flexibly Now and Into the Future
    The HPE MSA 2052 SAN Storage delivers data-in-place upgrades protecting drive investments and reduces data migrations.Start small and scale as needed with any combination of Solid State Drives (SSDs), enterprise or midline SAS disk drives.
HPE Modular Smart Array 2052 SAS Dual Controller LFF Storage - solid state / hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
1.6 TB
Max Supported Capacity
960 TB
Maximum LUNs
512
2 (installed) / 12 (max)
Supported Drives
SAS-2
Storage Controller
RAID (SAS 6Gb/s) - RAID 1, 5, 6, 10
Storage Controller Quantity
2
Hard Drive
2 x 800 GB SSD Mixed-Use
HP-UX, SuSe Linux, Apple MacOS X, Microsoft Windows, Red Hat Enterprise Linux, HP OpenVMS, Microsoft Windows Server 2012, VMware ESXi 5.x, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 R2 with Hyper-V, VMware ESXi 6.x
AC 120/230 V - 50/60 Hz
Power Redundancy
44.7 cm x 57.2 cm x 8.9 cm
18.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Enclosure Type
Rack-mountable - 2U
Chassis
2
Supported Devices / Modules Qty
12
Supported Drives
SAS-2
Storage
1.6 TB
960 TB
Maximum LUNs
512
Storage Capacity Details
Raw 960 TB
CPU
No CPU
Storage Controller
RAID (iSCSI)
Installed Qty
2
Interface Type
SAS 6Gb/s
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
8 GB
RAID Level
RAID 1, RAID 5, RAID 6, RAID 10
Storage Controller (2nd)
Installed Qty
2
Hard Drive
SSD
2 x 800 GB
Mixed-Use
Expansion Bays
12 (total) / 10 (free) - 3.5" LFF
4 x Ethernet 10Gb (iSCSI) / 16Gb Fibre Channel , 2 x mini-USB 2.0 (management) , 2 x Ethernet 1000Base-T (management) - RJ-45 , 2 x SAS
Systems Insight Manager (SIM)
Software Included
HPE Advanced Data Services Suite, HPE 3PAR Virtual Copy, HPE MSA Remote Snap Software
CISPR 22 Class A, CISPR 24, EN55022, GS, EN55024, CCC, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, KN24, KN22 Class A, CNS 13438 Class A, ICES-003:2004 Class A, EN61000-3-3, EN61000-3-2
ENERGY STAR Certified
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
374 Watt
44.7 cm
57.2 cm
8.9 cm
18.4 kg
Limited warranty - parts - 3 years
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
Brand: HPE
Price Range Ex VAT: 1500+
