HPE MSA 2050 SAS NEBS SFF Storage
Quicklinx: F8MNWS00 Mfr#: Q1J32A
Looking for affordable, high-performance shared storage? The HPE MSA 2050 SAN Storage is a flash ready system designed for affordable application acceleration ideal for small and remote office deployments. Don't let the low cost fool you, it gives you the combination of simplicity, flexibility to grow now, and advanced features you may not expect in an entry-priced array. Start small and scale as needed with any combination of solid state disks (SSD), high-performance enterprise, or lower-cost midline SAS-based drives. HPE MSA 2050 SAN Storage has been the industry-leading entry storage Fibre Channel (FC) platform for the past eight years, with nearly 500,000 systems sold worldwide . Delivers 2x higher performance than the previous generation at the same price, delivering in excess of 200,000 IOPS. It's seriously simple and affordable flash-ready storage to help you get the most performance for the lowest cost.
  • Accelerates Applications Affordably
    The HPE MSA 2050 SAN Storage performs at 200,000 IOPS delivering affordable application acceleration for small to medium-sized businesses both local and remote.Flexible base model delivers 2x more performance than previous generation HPE MSA 2040 SAN Storage for the same price.
  • Advanced Data Services With No Experience Required
    The HPE MSA 2050 SAN Storage is easy to install, easy to use, easy to maintain, no previous storage expertise required.Automated tiering dynamically responds to workload changes, so you don't have to.
  • Keep Your Business Running with Expanded Data Protection Features
    The HPE MSA 2050 SAN Storage delivers updated virtualized snapshot technology making data protection and instant recovery a snap.Remote replication with Fibre Channel (FC) and iSCSI supports an affordable disaster recovery solution.
  • Grow Flexibly Now and Into the Future
    The HPE MSA 2050 SAN Storage supports data-in-place upgrades protecting drive investments and reduces data migrations.Start small and scale as needed with any combination of Solid State Drives (SSDs), enterprise or midline SAS disk drives.
HPE Modular Smart Array 2050 SAS NEBS SFF Storage - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
76.8 TB
Maximum LUNs
512
0 (installed) / 24 (max)
Supported Drives
SAS-3
Storage Controller
RAID (SAS 12Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 50
Storage Controller Quantity
2
HP-UX, SuSe Linux, Apple MacOS X, Microsoft Windows, Red Hat Enterprise Linux, HP OpenVMS, Microsoft Windows Server 2012, VMware ESXi 5.x, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012 R2 with Hyper-V, VMware ESXi 6.x
DC -40 -75 V
Power Redundancy
44.7 cm x 49.5 cm x 8.9 cm
18.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
24
Supported Drives
SAS-3
Storage
76.8 TB
Maximum LUNs
512
Storage Controller
RAID
Installed Qty
2
Interface Type
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
Installed Qty
2
Expansion Bays
24 (total) / 24 (free) - 2.5" SFF
8 x SAS 12Gb/s , 2 x mini-USB 2.0 (management) , 2 x Ethernet 1000Base-T (management) - RJ-45
Systems Insight Manager (SIM)
CISPR 22 Class A, CISPR 24, GS, EN55022 Class A, CCC, ICES-003 Class A, IEC 60950-1, EN 60950-1, WEEE, RoHS, NEBS, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, KN24, K60950-1, KN22 Class A, China RoHS, AS/NZS CISPR 22, EN61000-3-2, EN61000-3-3, EN 55024 Class A, CNS 13438 Class A
ENERGY STAR Certified
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
DC -40 -75 V
432 Watt
44.7 cm
49.5 cm
8.9 cm
18.4 kg
Limited warranty - parts - 3 years
5 °C
10 - 90% (non-condensing)
Sound Emission
55 dBA
