HPE MSA 2050 LFF Disk Enclosure
Quicklinx: F8MJWS00 Mfr#: Q1J06A
Hurry, only 2 left in stock!
£1,789.69 ex VAT
£2,147.62 inc VAT
Looking for affordable, high-performance shared storage? The HPE MSA 2050 SAN Storage is a flash ready system designed for affordable application acceleration ideal for small and remote office deployments. Don’t let the low cost fool you, it gives you the combination of simplicity, flexibility to grow now, and advanced features you may not expect in an entry-priced array.
HPE Modular Smart Array 2050 SAN LFF Disk Enclosure - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
0 (installed) / 12 (max)
Supported Drives
SAS-3
AC 120/230 V
Power Redundancy
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
0
Supported Devices / Modules Qty
12
Supported Drives
SAS-3
Expansion Bays
12 (total) / 12 (free) - 3.5" LFF
1 x SAS 12Gb/s
2 x mini SAS cable - 50 cm
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Brand: HPE
Price Range Ex VAT: 1500+
