HPE Modular Smart Array 400GB 12G SAS MU 2.5" Solid State Drive
Quicklinx: CRT1WS00 Mfr#: N9X95A
Do you need more performance from your HPE ProLiant Sever series or HPE Synergy platforms? HPE Solid State Drives (SSDs) deliver exceptional performance and endurance while reducing power consumption for customers with applications requiring high random read and write IOPs performance. Categorized by Read Intensive (RI), Mixed Use (MU), and Write Intensive (WI), you can choose the right SSD that tailors to your workload demands. Also, you can prevent data loss and monitor the SSD life with HPE SmartSSD Wear Gauge compatibility in management tools. Leveraging NAND Flash technology, they support HPE ProLiant servers including Gen9 and server storage platforms. Available as Small Form Factor (SFF) and Large Form Factor (LFF) hot plug devices, non-hot plug SFF devices, and SFF Quick Release devices, you have great flexibility in your installation. These drives deliver higher performance, better latency, and more power-efficient solutions when compared with traditional rotating media.
  • Provides simplicity and lower total cost of ownership
    HPE Solid State Drives deliver reduced power consumption, providing improved IOPS/W versus rotating media while reducing datacenter cooling costs. With compatibility in management tools, SmartSSD Wear Gauge prevents data loss and monitors SSD life.
  • Increases the efficiency of your server
    HPE Solid State Drives (SSDs) allow you to get the most out of your server with more compute per watt with SSDs. Utilizes the unique Power Advisor tool for SSD and system power planning. Uses self-describing LED's that reduces drive activity confusion.
  • Accelerate workload performance with high performing HPE Solid State Drives
    HPE Solid State Drives (SSDs) achieve higher Input/Output Per Second (IOPs) to enhance the performance of your data center. Experience the latest technology in the market and the industry-leading performance of 12 Gb SAS SSDs and NVMe PCIe SSDs. Gives you faster access to data with excellent latency. Provides you with the most complete portfolio of choices across SAS and SATA and first to market with latest technologies.
  • Delivers the high reliability you can count on in your data center
    HPE Solid State Drives (SSDs) are rigorously tested 2.4 million hours to achieve the quality standards you need. You can rely on SSDs in various environments as they can tolerate significantly high operating shock and vibration levels. HPE firmware provides compatibility with ProLiant Server series and HP controllers for consistency of performance. Maintains data accuracy with full data-path error detection. Delivers high availability with power loss protection that continues to protect your data even when the datacenter loses power.
HPE Mixed Use - SSD - 400 GB - SAS 12Gb/s
Solid state drive - hot-swap
400 GB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
3-year warranty
Modular Smart Array 1040 Dual Controller SFF Bundle, 1040 Dual Controller SFF Storage, 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle Performance Tier, 2040 SAN Dual Controller SFF Storage, 2040 SAN w/o SFP Bundle Performance Tier, 2040 SAN w/o SFP SFF Bundle, 2040 SAS Dual Controller SFF Bundle, 2040 SAS Dual Controller SFF Bundle Performance Tier, 2040 SAS Dual Controller SFF Storage, 2040 SFF Chassis, 2040 SFF DC-power Chassis
400 GB
2.5" SFF
SAS 12Gb/s
Performance
Drive Transfer Rate
1.2 GBps (external)
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
HPE Modular Smart Array 1040 Dual Controller SFF Bundle, 1040 Dual Controller SFF Storage, 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle Performance Tier, 2040 SAN Dual Controller SFF Storage, 2040 SAN w/o SFP Bundle Performance Tier, 2040 SAN w/o SFP SFF Bundle, 2040 SAS Dual Controller SFF Bundle, 2040 SAS Dual Controller SFF Bundle Performance Tier, 2040 SAS Dual Controller SFF Storage, 2040 SFF Chassis, 2040 SFF DC-power Chassis
