Would you like to accelerate your performance-hungry applications with flash storage? The HPE MSA 2042 SAN Storage offers an entry level storage platform with built-in hybrid flash for application acceleration and high-performance. It is ideal for performance-hungry applications and includes 800 GB of Solid State Drive (SSD) capacity. The all-inclusive set and forget software suite includes built-in, real-time data tiering that dynamically moves frequently used data to flash and less used data to lower-cost media tiers. This suite also includes 512 snapshots out-of-the-box for instant recovery, and remote replication for affordable application availability. The software delivers management tools that are ideal for IT generalists and server administrators. The MSA 2042 allows for flexible growth now and into the future. Data-in-place upgrades reduce data migration and drive investments. Start small and scale as needed with any combination of SSD, SAS or midline SAS drives.
Accelerates Applications Affordably
The HPE MSA 2042 SAN Storage is one of the industry's fastest entry-level storage arrays, and comes with 800 GB of SSD capacity standard.The all-inclusive set and forget software suite includes built-in, real-time data tiering that dynamically moves constantly used data to flash and less used data to lower-cost media tiers.New MSA 2042 models now optimized based on your typical target workload; Write Intensive or Mixed Use. The MSA 2042 offers customers the right SSD option for every application. -
Set It and Forget It
The HPE MSA 2042 SAN Storage provides built-in, real-time tiering dynamically moving constantly used data to flash for increased performance and moving less used data to lower-cost media.All-inclusive software suite and simple management tools for IT generalists and server administrators. -
Reduces Risk with Modern Disaster Recovery and Business Continuity Tools
The HPE MSA 2042 SAN Storage allows 512 snapshots standard for faster recovery.Remote replication included for affordable application availability. -
Grow Flexibly Now and Into the Future
The HPE MSA 2042 SAN Storage has data-in-place upgrades reduce data migration and drive investments.Start small and scale as needed with any combination of SSD, SAS or Midline SAS drives.
- HPE Modular Smart Array 2042 SAN Dual Controller SFF Storage - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 800 GB
- Interface
- 8Gb Fibre Channel, iSCSI (1 GbE), iSCSI (10 GbE), 16Gb Fibre Channel
- Installed Devices / Modules Qty
- 2 (installed) / 24 (max)
- Supported Drives
- SAS-2
- Storage Controller
- RAID (SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 50
- Storage Controller Quantity
- 2
- Hard Drive
- 2 x 400 GB SSD Mixed-Use
- OS Required
- HP-UX, Red Hat Linux, Apple MacOS X, SUSE Linux Enterprise Server, HP OpenVMS, Microsoft Windows Server 2008 R2, Oracle Solaris, Microsoft Windows Server 2012, VMware ESXi 5.x, Microsoft Windows Server 2016, VMware ESXi 6.x
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 44.7 cm x 49.53 cm x 8.9 cm
- 14.2 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 2
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SAS-2
Storage
- 800 GB
- HDD Array External Interface
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- SSD
- Capacity
- 2 x 400 GB
- Mixed-Use
- Expansion Bays
- 24 (total) / 22 (free) - 2.5" SFF
- 8 x 8Gb Fibre Channel / 16Gb Fibre Channel / Ethernet 10Gb / Ethernet 1000 , 2 x USB - mini-USB Type A , 2 x management - RJ-45 , 2 x SAS
- OS Required
- Software Included
- HPE Advanced Data Services Suite
- VCCI, EN55022, GS, ICES-003, EN55024, CCC, FCC Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, RoHS, CAN/CSA C22.2 No. 60950-1-03, KN24, KN22 Class A, China RoHS, AS/NZS CISPR 22, CNS 13438, EN61000-3-2, EN61000-3-3
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 44.7 cm
- 49.53 cm
- 8.9 cm
- 14.2 kg
- Limited warranty - parts - 3 years
- 5 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 55 dBA
