Changing storage needs for server customers now requires greater levels of performance and functionality at a lower cost of ownership. The next generation HPE MSA 2040 Storage arrays raises the bar & uniquely addresses HPE ProLiant customers' shared storage and data protection needs, reduces TCO while dramatically increasing performance using technologies such as Solid State Drives, Snap and Volume copy, Replication and SEDs. The MSA 2040 Storage arrays are positioned to provide an excellent value for customers needing increasing performance to support initiatives such as consolidation and virtualization. The MSA 2040 delivers this performance by leveraging new controller architecture with a new processor, four ports with 4GB cache per controller & using drive technologies such as SSDs. The MSA 2040 Storage ships standard with 64 Snapshots and Volume Copy enabled for increased data protection and allow replication with optional Remote Snap software between arrays (FC or iSCSI only).
Simple: Flexible Architecture
The integrated setup and management Web-based Interface (WBI) makes MSA easy to manage for HPE ProLiant/BladeSystems administrators and IT generalists.Leverage the latest Large or Small Form Factor hard disk drives –choice of High-performance Enterprise-class SAS or high-capacity SAS Midline drives based on application, performance and budget requirements.On-board management tools augment OS and hypervisor views navigate firmware upgrades, monitor array performance with ease locally or remotely. -
Affordable: Popular iSCSI/SAS/Fibre Channel Configurations
Dual controller configurations are standard and available at single controller price points.More capacity/performance within your budget.Latest MSA technology at lower cost. -
Fast: The MSA 1040 Delivers up to 50% More Performance Compared to P2000 G3
The HPE MSA 1040 SAN Storage leverages the 4th generation MSA architecture, 2-port controllers with 4 GB Cache each, faster processor and a performance optimized I/O engine.Increased performance translates into better application response times and facilitates entry consolidation and virtualization initiatives. -
Futureproof: Built-in Expandability Along with an HPE MSA 2040 Upgrade Option
Add Disk Enclosures as needed to boost capacity and spindle count. Most low-cost entry arrays don't allow expansion.Data-in-Place upgrades eliminate time-consuming and risky data migrations.HPE MSA 1040 SAN Storage allow simple controller swap to flagship HPE MSA 2040. Other value-priced arrays force you to compromise.
- HPE Modular Smart Array 1040 Dual Controller SFF Bundle - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 2.4 TB
- Max Supported Capacity
- 43.2 TB
- Interface
- 8Gb Fibre Channel
- Maximum LUNs
- 512
- Installed Devices / Modules Qty
- 4 (installed) / 24 (max)
- Supported Drives
- SAS-3
- Storage Controller
- RAID (SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 50
- Storage Controller Quantity
- 2
- Hard Drive
- 4 x 600 GB HDD
- OS Required
- HP-UX, Red Hat Linux, SUSE Linux Enterprise Server, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- Manufacturer Selling Program
- HP Top Value Lite
- 44.7 cm x 49.5 cm x 8.9 cm
- 26 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- 4
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SAS-3
Storage
- 2.4 TB
- 43.2 TB
- HDD Array External Interface
- 8Gb Fibre Channel
- Maximum LUNs
- 512
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Cache / Buffer Size (Max)
- 8 GB
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 50
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- HDD
- Capacity
- 4 x 600 GB
- Expansion Bays
- 24 (total) / 20 (free) x hot-swap - 2.5" SFF
- 4 x 8Gb Fibre Channel - SFP+ , 2 x USB (management) , 2 x Ethernet 1000Base-T (management) - RJ-45 , 2 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
- OS Required
- Firmware upgradable
- FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 61000-3-2, GS, EN 61000-3-3, EN55022 Class A, CCC, FCC Part 15, ICES-003 Class A, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE, RoHS, EN55024 Class A, VCCI Class A, KN24, KN22 Class A, China RoHS, CNS 13438
- HP Top Value Lite
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 337 Watt
- 44.7 cm
- 49.5 cm
- 8.9 cm
- 26 kg
- Limited warranty - parts - 3 years
- 5 °C
- 40 °C
- 10 - 90% (non-condensing)
- Sound Emission
- 55 dBA
