HPE LTO6 Ultrium 2.5TB/6.25 TB Data Cartridge
Quicklinx: C44QWS00 Mfr#: C7976AN
Type: LTO Ultrium
Native Capacity: 2.5TB
£500.87 ex VAT
£601.04 inc VAT
With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
  • Saves time, money and mistakes
    Manual labeling is a slow, laborious, error-prone process. With custom labeled media, IT staff no longer have to waste hours peeling, sticking and attaching barcode labels to individual cartridges. HPE barcode labels use Tri-Optic products to produce labels that will not peel, distort, reflect or fade. Labels are applied professionally, in a clean, controlled environment to prevent backup disruptions and drive damage.
  • RFID non-custom labels
    Operational efficiencies as a result of bulk reading of media and line of sight reading not being necessary. Increases the real time visibility of media so the datacenter can quickly recognize a missing tape and thus reduce a chance of data breaches which can incur heavy fines and brand damage.
  • Simple, fast and convenient
    Each 20-pack of labeled tapes follows a sequence for ease of use: predetermined by HPE and guaranteed to be unique. No codes are ever repeated. Pre-sequenced media cuts lead times to days because they can be shipped off the shelf, usually within 2-3 working days. HPE Non-custom Labeled cartridges can be used in any HPE and non-HPE LTO Ultrium, DLT and SDLT drives.
  • Excellent value for money
    HPE's Non-custom Labeled media costs the same as its unlabeled media. RFID non-custom label: provides strong ROI as a result of operational efficiencies. Now includes LTO-7 data cartridges.
HPE RW Data Cartridge - LTO Ultrium 6 x 20 - 2.5 TB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 6
Media Included Qty
20
Purple
Native Capacity
2.5 TB
Compressed Capacity
6.25 TB
Tape Length
846 m
Cartridge Labeling
Write-on labels
Metal Particle (MP)
StorageWorks SAS Rack-Mount Kit; StoreEver MSL2024 Ultrium 6250, MSL4048 Ultrium 6250, MSL8096 Ultrium 6250; StoreEver 1/8 G2 Ultrium 6250
LTO Ultrium
Tape Cartridge
Ultrium 6
Media Included Qty
20
Cartridge Labeling
Write-on labels
Purple
Media
Native Capacity
2.5 TB
Compressed Capacity
6.25 TB
Tape Length
846 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
10 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE StorageWorks SAS Rack-Mount Kit , HPE StoreEver MSL2024 Ultrium 6250, MSL4048 Ultrium 6250, MSL8096 Ultrium 6250 , HPE StoreEver 1/8 G2 Ultrium 6250
Type: LTO Ultrium
Brand: HPE
Price Range Ex VAT: 500 - 750
