HPE LTO-5 Ultrium 3 TB RW Eco Pack Custom Labelled Cart 20 pk
Quicklinx: 7DSVWS00 Mfr#: C7975AC
Type: LTO Ultrium
Native Capacity: 1.5TB
£473.47 ex VAT
£568.16 inc VAT
With HP Custom Labeled Media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. For no extra charge, cartridges can be supplied with barcode labels bearing your own specified sequences. HP rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HP Automation Group to evaluate and warrant the performance of its labels. These labels are professionally applied in a clean environment to ensure 100% readability accurate storage and retrieval in busy, automated tape libraries. Custom labeled cartridges ensure 100% label readability and can be ordered online in packs of 20. For those customers who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the customized label and offers tracking, audit and security advantages for those with IT asset tracking systems.
  • Saves Time, Money and Mistakes
    Manual labeling is a slow, laborious, error-prone process. With custom labeled media, IT staff no longer have to waste hours peeling, sticking and attaching barcode labels to individual cartridges.HPE barcode labels use Tri-Optic products to produce labels that will not peel, distort, reflect or fade. Labels are applied professionally, in a clean, controlled environment to prevent backup disruptions and drive damage.RFID custom labels: Operational efficiencies as a result of bulk reading of media and line of sight reading not being necessary.RFID custom labels: Increases the real time visibility of media so the datacenter can quickly recognize a missing tape and thus reduce a chance of data breaches which can incur heavy fines and brand damage.
  • Simple, Convenient and Customized
    All HPE custom labeled cartridges can be ordered with a unique sequence for the barcode labels. As long as the format allows for it, any sequence can be requested.HPE Custom Labeled cartridges can be used in any HPE and non-HPE LTO Ultrium, DLT and SDLT drives.
  • Excellent Value for Money
    HPE's Custom Labeled media cost the same as its unlabeled media. There is no charge for customized labeling.RFID custom label: provides strong ROI as a result of operational efficiencies.
  • Broad portfolio of custom and non custom options
    Available LTO-1 through LTO-6.RW and WORM media.Custom (user chooses sequence) and non custom (off the shelf) options.Tri Optic and RFID options.
HPE Ultrium RW Custom Labeled No Case Data Cartridge - LTO Ultrium 5 x 20 - 1.5 TB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 5
Media Included Qty
20
Light blue
Native Capacity
1.5 TB
Compressed Capacity
3 TB
Tape Length
846 m
Cartridge Labeling
Labeled
Metal Particle (MP)
HPE MSL2024 Ultrium 3000, MSL4048 Ultrium 3000, MSL8096 Ultrium 3000, MSL8096 Ultrium 3280; 1/8 G2 Tape Autoloader Ultrium 3000; LTO-5 Ultrium 3280; StoreEver MSL4048 LTO-5 Ultrium 3000, MSL6480 Scalable Base Module
LTO Ultrium
Tape Cartridge
Ultrium 5
Media Included Qty
20
Cartridge Labeling
Labeled
Light blue
Media
Native Capacity
1.5 TB
Compressed Capacity
3 TB
Tape Length
846 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE MSL2024 Ultrium 3000, MSL4048 Ultrium 3000, MSL8096 Ultrium 3000, MSL8096 Ultrium 3280 , HPE 1/8 G2 Tape Autoloader Ultrium 3000 , HPE LTO-5 Ultrium 3280 , HPE StoreEver MSL4048 LTO-5 Ultrium 3000, MSL6480 Scalable Base Module
Type: LTO Ultrium
Brand: HPE
