HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
Outstanding Capacity and Performance, Monitoring Capabilities, Hardware Encryption & StoreOpen/LTFS
HPE StoreEver LTO Ultrium Tape Drives provide up to 30TB of compressed capacity on a single cartridge.HPE StoreOpen Standalone and Linear Tape File System (LTFS) allows customers to store data in an open format making the tape self-describing and file-based.Enables even the tightest backup window to be met with unprecedented performance.Provides highest level of security with encryption for strong backup data privacy to secure confidential information and address compliance quickly and with fewer cartridges. -
Reliable, Well Connected and Compatible
Allows the tape drive to continuously adjust the speed of the drive to keep drives streaming to maximize performance and reduce start/stops which significantly increase reliability of HPE drives and media.SAS models qualified on HPE and non-HPE servers; including popular platforms from vendors such as Dell, IBM, and Sun. See DAPR compatibility matrix on the right rail for more information.Extensive list of supported backup and archiving software applications from HPE, CA, VERITAS, Legato, Tivoli, and many more.Design leveraged from previous HPE LTO tape drives to deliver confident backups at high duty cycles. -
Complete Solution Straight out of the Box
Provides HPE LTO media, cables, user guides and a download flyer for the fully functional 60-day trial of Veritas Backup Exec. Customers can receive a 50% discount off Veritas MSRP.For IT organizations with stringent, long-term data retention requirements, WORM data protection capability offers a simple and secure method for archiving records allowing customers to affordably meet the toughest industry compliance regulations.
- HPE StoreEver LTO-3 Ultrium 920 - tape drive - LTO Ultrium - SAS
- Tape drive
- Recording Standard
- LTO Ultrium 3
- Enclosure Type
- External
- Interface Type
- SAS
- 22.3 cm x 29.5 cm x 7.7 cm
- 4.65 kg
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 400 GB (native) / 800 GB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 2, Ultrium 3
- Data Transfer Rate (native)
- 60 MBps (216 GBph)
- Data Transfer Rate (compressed)
- 120 MBps (432 GBph)
- Manufacturer Selling Program
- HP Top Value
- Tape drive - LTO Ultrium
- LTO Ultrium 3
- Enclosure Type
- External
- Interface Type
- SAS
- 22.3 cm
- 29.5 cm
- 7.7 cm
- 4.65 kg
Storage Removable
- LTO Ultrium
- Capacity
- Average Seek / Access Time
- 64 sec
- Buffer Size
- 64 MB
- 1 x SAS - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
- Media Included Qty
- 5
- Cables Included
- 1 x SAS cable
- MTBF
- 250,000 hour(s)
- TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, RoHS2
- HP Top Value
- Software Included
- HP Library and Tape Tools
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
