HPE Jetdirect ew2500 802.11g Print Server
HP Jetdirect ew2500 802.11b/g Wireless Print Server
Quicklinx: 6P17WS00 Mfr#: J8021A#ACC
Wired / Wireless: Wired, Wireless
Protocol: Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Form Factor: External
Interface: USB 2.0
Compatibility: PC
Hurry, only 1 left in stock!
£224.51 ex VAT
£269.41 inc VAT
Get the best of both worlds - share HP printers and multifunction products via wireless or wired networks. Send and print documents protected by IPSec, 802.11x and several encryption options. Enjoy easy installation, set up and management.
  • Ensure your confidential information stays private with multiple security features
    Keep your confidential information private and secure with multiple security features when using HP wireless solutions. IPv6 provides more IP addresses than IPv4, plus the added security of IPSec.
  • Integrate a wide variety of printers into your wireless network or plug in to your Ethernet system
    Share printers and MFPs across your network: connect wirelessly to your 802.11 b/g wireless network or connect to your wired Ethernet system. The print server is compatible with a wide variety of printers, operating systems and network protocols.
  • Get connected with easy installation, setup and network management
    Get connected with easy installation and setup. Keep tabs on the server's status with convenient lights and test button. Easily manage your printing network with HP Web Jetadmin.
HP JetDirect ew2500 - print server
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
10 cm x 13.5 cm x 3.3 cm
140 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 802.11b/g
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x
1-year warranty
Color LaserJet Managed M651; Color LaserJet Managed Flow MFP M880; LaserJet Enterprise MFP M525, MFP M575; LaserJet Enterprise Flow MFP M880; LaserJet Managed MFP M525; LaserJet Managed Flow MFP M525; LaserJet Pro M706; Officejet Managed Color MFP X585; Officejet Managed Color Flow MFP X585
Print server
External
USB 2.0
Ports
10/100 Ethernet
Wireless, wired
Cabling Type
Remote Management Protocol
SNMP 3, HTTPS
1 x 100Base-TX - RJ-45
1 x USB 2.0
1 x USB cable (external) , 1 x network cable (external)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 40-bit WEP, 104-bit WEP, TKIP, WPA, WPA2
Software Included
Drivers & Utilities
10 cm
13.5 cm
3.3 cm
140 g
Limited warranty - 1 year
HP Color LaserJet 2700, 2700n, CM3530 MFP, CM3530fs MFP, CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP, CM6030 MFP, CM6030f MFP, CM6040 MFP, CM6040f MFP, CP1510, CP1515n, CP1518ni, CP2025, CP2025dn, CP2025n, CP2025x, CP3505, CP3505dn, CP3505n, CP3505x, CP3525, CP3525dn, CP3525n, CP3525x, CP4005dn, CP4005n, CP6015de, CP6015dn, CP6015n, CP6015x, CP6015xh , HP Color LaserJet Enterprise CP4025dn, CP4025n, CP4525dn, CP4525n, CP4525xh, CP5525dn, CP5525n, CP5525xh, M651dn, M651n, M651xh , HP Color LaserJet Managed M651dnm, M651xhm , HP Color LaserJet Managed Flow MFP M880zm, MFP M880zm+ , HP Color LaserJet Professional CP5225, CP5225dn, CP5225n , HP DesignJet T120 ePrinter, T520 ePrinter , HP LaserJet 4240, 5200L, 5200Lx, M3027 MFP, M3027x MFP, M3035 MFP, M3035xs MFP, M5025 MFP, M5035 MFP, M5035xs MFP, M9040 MFP, M9050 MFP, P2014, P2014n, P2015, P2015d, P2015dn, P2015n, P2015x, P2035, P2035n, P2055d, P2055dn, P2055x, P3005, P3005d, P3005dn, P3005n, P3005x, P4014, P4014dn, P4014n, P4015dn, P4015n, P4015tn, P4015x, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise 500 M551dn, 600 M601n, M4555 MFP, M4555f MFP, M4555fskm MFP, M4555h MFP, MFP M525dn, MFP M525f, MFP M575dn, MFP M575f, MFP M630dn, P3015, P3015d, P3015dn, P3015n, P3015x , HP LaserJet Enterprise Flow MFP M880z, MFP M880z+, MFP M880z+ NFC/Wireless direct , HP LaserJet Managed MFP M525fm , HP LaserJet Managed Flow MFP M525cm , HP LaserJet Pro M706n, P1606DN , HP Officejet Enterprise Color X555dn, X555xh , HP Officejet Managed Color MFP X585dnm , HP Officejet Managed Color Flow MFP X585zm , HP Officejet Pro 8000, 8000 Enterprise, 8000 Wireless, 8500 A909a, 8500 Premier A909n, 8500 Wireless A909g, 8500A A910a, 8500A Plus A910g, 8600 N911a, 8600 Plus N911g, 8600 Premium N911n, K5300, K5400, K5400dn, K5400dtn, K5400n, K5400tn, K550, K550dtn, K550dtwn, K850, K850dn, K8600, K8600dn, L7380, L7550, L7555, L7580, L7590, L7650, L7680, L7681, L7710, L7750, L7780
Wired / Wireless: Wireless
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Interface: USB 2.0
Compatibility: PC
Standards: IEEE 802.11g
Brand: HPE
Price Range Ex VAT: 150 - 300
