The Intel Gigabit CT Desktop NIC provides a complete end-to-end Gigabit solution from the server to the switch infrastructure and down to the desktop and workstation.
Connectivity you can count on
For PCs with PCI Express (PCIe) slots, the Intel Gigabit CT Desktop Adapter offers the newest technology for maximizing system performance and increasing end-user productivity. Specifically, the Intel Gigabit CT Desktop Adapter uses auto-negotiation to ensure the adapter runs at the highest available network speed (10, 100, or 1000 Mbps), and it maintains full bandwidth capacity with the dedicated bandwidth of a PCI Express input/output (I/O) bus to provide connectivity you can count on. This desktop adapter offers optimal performance in a low-cost, low-power, compact profile. Teaming support and an array of other advanced features enable customers to utilize this adapter as an entry-level server adapter as well. -
Enhancing desktop performance
Fast servers and server connections are important for high network performance. However, server speed cannot overcome the drag of slow desktop performance. When a desktop PC initiates a transaction with the network server, the server quickly performs its portion of the transaction, but must wait for the desktop PC to complete its part of the transaction. The slower the PC, the longer the server must wait for transaction completion before moving to the next transaction. With PCI Express Gigabit performance to the desktop, transactions on the PC side complete significantly faster, allowing the network to service more transactions faster. -
PCI Express makes Gigabit Ethernet even faster
PCI Express is the third-generation I/O standard with performance that supersedes the previous PCI and PCI-X slot standards. The key to PCIe performance is its higher dedicated I/O bandwidth. Unlike the PCI bus, which shares its I/O resources with all devices on the bus, PCIe dedicates its I/O to a single device. The Intel Gigabit CT Desktop Adapter allows you to take advantage of this dedicated I/O by combining Gigabit Ethernet with PCI Express to provide high-performance network connectivity for desktops with PCI Express slots. Make the Intel Gigabit CT Desktop Adapter your choice for applications utilizing rich media content such as video streaming, web applications, music, and gaming. -
Quick and easy installation
Like all Intel network adapters, the Intel Gigabit CT Desktop Adapter is supported by Intel PROSet Utility for Microsoft Device Manager and Intel PRO intelligent install. Intel PROSet simplifies adapter installation and gives you point-and-click power for configuring and managing all of your Intel network connections.
- Intel CT Desktop Adapter - network adapter - PCIe - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- Ports
- Gigabit Ethernet
- 2 cm x 12.1 cm x 5.7 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Network adapter
- Form Factor
- PCI Express x1
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Remote Management Protocol
- SNMP, RMON
- WOL
- 1 x 1000Base-T - RJ-45
- FCC Class B certified, TUV, TUV GS, cTUVus
- 2 cm
- 12.1 cm
- 5.7 cm
