Your basket is empty
HPE HP1410-24-2G Unmanaged Rackmount Switch
Quicklinx: 855ZWS00 Mfr#: J9664A
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
HPE OfficeConnect 1410 24 2G - switch - 24 ports - unmanaged - rack-mountable
Switch - 24 ports - unmanaged
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x 10/100/1000
Performance
Switching capacity: 8.8 Gbps , Throughput: up to 6.5 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
9216 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), DiffServ support, Quality of Service (QoS), Jumbo Frames support
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
33.6 cm x 16.9 cm x 4.4 cm
1.35 kg
Enclosure Type
Desktop, rack-mountable, wall-mountable
Subtype
Fast Ethernet
Ports
Performance
8K entries
Jumbo Frame Support
9216 bytes
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45
External power adapter
10.8 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, FCC Part 15 B, UL 60950-1, IEC 60950-1, EN 60950-1
33.6 cm
16.9 cm
4.4 cm
1.35 kg
Limited warranty - lifetime
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
855Z C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.08
855Z C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.53
855Z C2G 2m Cat6a Shielded Patch - Blue In Stock £6.47
855Z C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £41.04
